switched power source in engine bay to tap meth switch?
Old Feb 28, 2009 | 04:00 AM
hotwheelsrs1's Avatar
Default switched power source in engine bay to tap meth switch?
hey guys im installing a snow performance stage 2 meth injection kit on my sc'd tc, and i need to run a wire to a switched 12v source in the engine bay, anybody know where i can tap into one?
im installing it right now so if i can get an answer asap that would be great!
Old Feb 28, 2009 | 01:01 PM
crush02342002's Avatar
notice the blue wire with the tap connector on it, red wire going to tap connector. that blue wire is a switched 12v source and can be found in the little panel on the driverside front.
Old Feb 28, 2009 | 02:01 PM
Ace83's Avatar
Ronin Scion
you can also tap on the radiator fan wire
Old Feb 28, 2009 | 05:13 PM
thanks for the pic! Is that in the engine bay or behind the kick panel inside the car? Ill be home in like 30 to see where thats at...
J
Old Feb 28, 2009 | 05:57 PM
inside the car kick panel
Old Feb 28, 2009 | 06:06 PM
Is there anything in the engine bay i can tap?
Old Feb 28, 2009 | 06:17 PM
yeah, like ace said. pop the cover off of the fuse box in the engine bay and look for a switched source ther. just use a connector like this to tap into it
Old Feb 28, 2009 | 06:29 PM
So just try and find a switched slot in there that isnt used yet?
Old Feb 28, 2009 | 06:51 PM
Do u know which wire to tap on the fan connector that will give me 12v i dont have a meter...
Old Feb 28, 2009 | 10:26 PM
Ace83's Avatar
Ronin Scion
there's only two wires on each fan, use a mulitimeter to look for the positive.. fans always use 12v. Its much cleaner to use add a fuse like crush showed but I havent seen any that can go over 10amps.. you have a lot of options you can just tap inside and run it through the firewall
Old Feb 28, 2009 | 10:31 PM
well if u look under the fuse box cover, theres a connector with a bunch of wires comming off it, i tested them and alot of them are switched power, i just dont have a volt meter to see if they are a full 12v, cause just cause its there doesnt mean its a full 12v right?
then i wat just going to use a t tap on it...
Old Feb 28, 2009 | 10:34 PM
Ace83's Avatar
Ronin Scion
yeah you need some volt meter just to make sure
Old Feb 28, 2009 | 11:11 PM
well most likely it is going to be 12volts unless ther is a resister in the line......everything in the car uses 12 volts except for maybe some led's which will have a resister of somesort near it. but it is always a good idea to play it safe and check it with a meter first.......good luck
Old Feb 28, 2009 | 11:27 PM
alright, thanks guys, looks like i need to find a friend with a volt meter lol
Old Mar 1, 2009 | 12:00 AM
you can find em real cheap that will do what you need it to. home depot (electical section), wal-mart (automotive section), auto zone (behind counter normally), pep-boys (could be anyplace, they like to move thos bastards around)..take your pick...lmao
Old Mar 1, 2009 | 12:34 AM
Haha my dad has one so my bro is bringing it over later
Old Mar 1, 2009 | 01:45 AM
hey i got a cen-tech p30756 from my dad just now, anyone know what i should put it on to test for 12v its got a bunch of settings....
Old Mar 1, 2009 | 02:50 AM
v with a line and a dotted line, not the v with the squiggly line...lol
Old Mar 1, 2009 | 08:05 PM
well i got it all setup and tested last night and it works great, now just waiting for my bumpers to get finished at the bodyshop and the key to come in for the sc'er and i can make my tune appt!
Inazuma
20
May 3, 2023 01:58 AM
jaspercanda
Scion tC 2G Aero & Exterior
14
Feb 3, 2020 02:43 PM
Halo19boy
Jan 27, 2015 10:19 PM
fliggah
Dec 25, 2003 01:03 PM
Besk_one
Nov 17, 2003 09:28 PM
