A/T kit for TRD Supercharger
Any one know were i can get the A/T kit for the TRD superchager??? Tried putting it on my buddys A/T the other day and the mounting bracket is diff on the A/T from the 5 speed.
you can try any scion dealership. they should be able to look up the part number and order one for you. if not you can always try trdsparks.com. they do good service and can pretty much get anything you might need for the scion!
The dealerships a joke they just tell me everything has been Discontinued
When I tryed to put it on my buddy's tc witch is a A/T the bracket mounted but had a gap on the bottom bolt so I used a spacer. When I tried to put in the last bolt but the pulley the one that dose not come out cuz the shifts in the way it was like a 1/2 off can anyone explain this?
The transmission side bracket needs two spacers(1 for each bolt). Not sure what you mean by 1/2 off? Does the bolt not align, or will it not thread in all the way?
I mean its not lined up its off by 1/2 I'm talking about the bolt that dose not come out cuz the shafts in the way needed to go toward the tranny by 1/2 in. Could be that I only used a spacer on one side? Do you know how far out the it needs to be spaced, for the bracket that mounts to the tranny?
Here's the part number, can't post any links, doing this from a tablet
PTR01-21051
the A/T kit is 2 spacers for the bracket and a new pipe to relocate the trans dip stick.
the s/c has been discontinued for years now and the s/c didn't sell as well as they wanted,
so i wouldn't think the dealership would be able to find one that easily and some probably don't want to.
Yeah iv called all around dealers are no help! I'm just going to use washer and space it out that way I guess. As far as the dip stick Im just going to unbolt it and spin it around some how.
ColonelSanders85
Dec 9, 2020 09:44 AM
rain7905643
12
Jun 13, 2018 05:34 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
TheTripleC
Jan 4, 2015 06:46 PM
bracket, buy, kit, lining, pulleys, scion, spacer, supercharged, supercharger, tc, transmission, trd, wantedlooking, xb, xd
and what did you do about your dip stick?
