TRD S/C impeller washer
Old Jun 18, 2012 | 10:01 PM
RS2Blitz's Avatar
Default TRD S/C impeller washer
Hey all, I have and '06 trd s/c and I'm looking for the steel washer that goes in between the impeller and housing.
Here is a picture of the washer (courtesy of AZGuy):
http://i1149.photobucket.com/albums/...4/8a227845.jpg
If anyone knows where I can get one of these please let me know. My local machine shops have quoted my $250-$350 in order to custom make ONE (NOT worth it). I have also contacted Vortech directly, as well as Toyota/Scion, and neither sell the washer. According to machine shop techs and Vortech/Scion?Toyota ppl, the washer is specially made to tolerate high heat, pressure and rotation so it can not be replaced with just any.
Any feedback is appreciated. Thanks guys.
Old Jun 18, 2012 | 11:17 PM
scion86's Avatar
How did it brake
-Sent From DarkSide Sense 3.5 -
Old Jun 19, 2012 | 03:12 AM
AZGuy's Avatar
If you replaced the seal with one like i have then any quality steel washer with the same spacing will work. If you are still using the Vortech seal then you do need a washer to those dimensions but should not cost you that much to get. I would try searching Granger or similar to find a washer that would work.
Old Jun 19, 2012 | 01:18 PM
RS2Blitz's Avatar
Originally Posted by scion86
How did it brake
That's a good question that I can not answer because I honestly don't know how it happened. Half of the washer was shattered into tiny pieces while the other half remained intact but all scratched up.
Old Jun 19, 2012 | 01:20 PM
RS2Blitz's Avatar
Alright just to confirm, if I have the 928 seal, which I do, I can just buy any steel washer and use it without issue as long as it fits?
Old Jun 20, 2012 | 12:45 AM
RS2Blitz's Avatar
Would it be a big deal if the washer does not fit snugly onto the shaft?
Old Jun 20, 2012 | 02:35 AM
scion86's Avatar
How did u know it was broken did it make any sounds or oil leaking. Or did u just take your s/c apart and found it broke.
Just wondering I'm hearing some rattle noise from my blower only at 2500 rpm if I stay steady on it. No oil leaks. and I'm going to be replacing the bearings cause that's what I think it is. But now I'm wondering if its the washer lol.
Old Jun 20, 2012 | 04:29 AM
AZGuy's Avatar
I does need to fit snuggly, if need be buy a washer the right thinkness (also important) with a smaller hole than you need and hand reem it till it is a press fit. That is what I would do on the cheep.
Old Jun 20, 2012 | 01:02 PM
RS2Blitz's Avatar
Alright I will give that a try. thanks for the input.
Old Jun 20, 2012 | 01:06 PM
RS2Blitz's Avatar
When the sc was on the car, I could hear a rattling somewhat grinding sound from the compressor side. There was no oil leak cause my 928 seal was tight. If your sc has never been rebuilt, you NEED to do it.
Old Jun 20, 2012 | 09:00 PM
scion86's Avatar
Yea my blower is doing the same (dam) lol. its never been rebuilt just the shaft. I was going to rebuild it anyway. What bearings did u go with I was thinking of kiks
Old Jun 21, 2012 | 01:09 AM
RS2Blitz's Avatar
Got mine from here: http://www.superchargedscions.com/5652.html
rvascion
Nov 12, 2020 03:23 AM
rain7905643
Jun 13, 2018 05:29 AM
airmankevin1
Nov 17, 2015 05:44 AM
BlingSlade
Sep 5, 2015 08:52 AM
