TRD supercharged: stock dyno.
Blue=stock Red=stock with HC trap removed and TRD high flow filter
3rd gear, temperature 95 degrees
Stock: 183.47 whp 164.77 wtq
With filter 185.5 whp 166.26 wtq
4th gear
with hc filter removed and trd high flow filter 187.3 whp 168.26 wtq
183?? i guess its a bit low either i'm not getting the full 7psi, or the temperature. It was 95* F in the shop, the car was already heat soaked from the 10 mile drive to the shop. After the second run-in which i got 185whp- I touched the supercharger housing and it was easily 200*F, can you imagine 200*F air going into the engine, that kills power.
i doubt that the temperature of your s/c had dramatically hurt your performance.....when most people talk about heat soaked, it either for that 10 miles, you werer gunning every light, or accelerating in boost for the whole 10 miles....of course that thing is gonna get hot, its the nature of going FI.....but people have driven over 100 miles to go get a tune, and put out the same numbers....also, with the s/c, don't you install a new cooler operating thermostat?
^ i know it wont hurt it drastically but a little cooldown time and an ambient temp of about 70-75*F would make a small difference... and yes the s/c kit comes with a 160* thermostat.
Originally Posted by Wyatt_Herb
Interesting considering there have been two stock supercharged 07's that dyno'd at 200+ whp.
