trd supercharger
Crubel.
Also. The only thing you might want to replace down the road. Is the bearing. When you swap out the pulley. It makes tge stock one go bad faster. If you ever have it happen. Look for a full ceramic bearing.
IDK paul, it usually isn't a habit of mine to second guess you, but when i had the TRD supercharger, using the supplied 410 or whatever they were injectors with the 9.5 psi nst pulley, and the TRD reflash, my intake temps would usually only be 10 above ambient air temp. i think the one really hot day i took it to the track it when it was 110 degrees, i don't remember seeing anything higher than 15-20 degrees above ambient air intake temp, and i did 9 runs back to back.
Yes, and I am glad you asked about this.
The 550cc injectors were not enough fuel delivery when running 9+ PSI on the TRD S/C. The reason being is that you do not have many ways on this setup of keeping charge temps down, which only leaves you with a hand-full of options...
1) Add some form of intercooling
2) Run a higher quality fuel with more detonation threshold
3) Run conservative timing with a richer AFR on a pump fuel (ie. 93)
I noticed that the duty cycles from AFRs we had to run on a 550 injector where rather high, which if you are planning to expand any more with a larger pulley or do not want to run a REALLY high duty cycle, then a 700 is an awesome choice.
or anything over 15000rpm. should do the job. depending on the pulley you upgrade to. ceramics are way to expensive and not necessary if your just upgrading for the 9.5 psi pulley. i just got my shaft section rebuild by some dude that rebuilds top fuel dragsters SC in MO. all he did on on my shaft end was replace the bearings for better ones and used some high velocity grease. its really not the bearings/ shaft that causes the problem its the lubricating factor.
Remember, if you hear/feel that there is a problem it is most likely too late, the bearings are damaged, and if the bearings are damaged most likely the TRD shaft is damaged.
Another benefit of my setup is that the shaft will take a lot more abuse before its damaged, the bearings should toast way before any shaft damage occurs. But then again if you use the grease and do a grease fitting, shouldn't have to worry about anything breaking.
Also, Datswhtshsed, is correct heat is the number one killer in this case. As a perfect example, most of my orders are from places like TX, CA, FL
I think it just has to do with luck lol. I had the s/c over a year before and it wasn't bad at all to me. Except for the lack of power. I made 270whp. So I went turbo instead. Either way going s/c or turbo you will get problems regardless.
There are a ton of people that dont have any problems with the SC you have to understand that people will only post when there is something wrong with their sc hence you hear more negative than positive
Exactly, but it doesn't hurt to change the shaft/bearings out either, especially for the 05-06 guys buying used s/c's.
Isnt the IAT sensor in the maf? If so and you are reading intake temps off of a scan gauge or other device reading the factory sensors, it is reading intake temps at the maf sensor, so it does not give you reference of the actual air temp to the engine.
I ran 550's with the 9.5 psi pulley also tuned to around 10.5-10.9 and the injectors were reading about 78% duty cycle, when I switched to ethanol and a Walbro, the duty cycle on the 550's were approaching low 90s. I would go bigger if I did it again...
Chucktown...are you still looking for injectors solutions?
Supply-wise, on paper, the 440cc should be able to handle the basic setup and the 550cc should be able to cover anything else you'd really be able to through at the engine with a supercharger on it.
...but Paul's been around this game for quite a bit. He's just looking out for the benefit of keeping your engine healthy from the experiences he's had tuning on these cars.
If you have a good tuner, there won't be any tuning difficulties between the 440cc/550cc/700cc injectors. ...and it's always nice to have a little headroom for what ever the future may bring.
