trd supercharger
Old Jul 11, 2010 | 12:48 PM
  #41
Thorium06's Avatar
Originally Posted by kikcaffine
I dont understand why the injectors are maxing out at such a low amount of boost. The 370's on my Rb25 @ 9.5psi are no where near maxing. Nor were the 550's on my SR @ 16psi.
First reason is the returnless fuel system, second reason your rb motor has six injectors feeding smaller cylinders compared to our four. The supercharger also makes a lot more power on the motor than what is seen at the wheels.
Old Jul 11, 2010 | 10:21 PM
  #42
Datswhtshsed's Avatar
^^ isnt that the usual case?
Old Jul 12, 2010 | 05:14 AM
  #43
kikcaffine's Avatar
Its still 2.5L though so its using more fuel? Is the returnless fuel system that big of a deal when it comes to fueling these things?
Old Jul 12, 2010 | 01:04 PM
  #44
Thorium06's Avatar
Well if both engines are at the same power level and flowing approximately the same amount of air, then the inline 6 has two more cylinders over the 2a to spread the load. Each cylider would require less air and fuel per cycle on a 6 instead of a 4. Also, each rb25 cylinder is much smaller volume than a 2az, because 2.5l although slightly larger than our 2.4 is the total displacement of all six cylinders.
Having a returnless style fuel system is also a huge disadvantage especially with boost. Our systems are designed to have the vaccum of the engine help draw the fuel from the injectors into the firing chamber, which has its limitations when the volum e the injectors are firing into has positive pressure thus forcing the fuel back in. A return style system would let the whole system be under constant pressure allowing it to flow much more effeciently.
Old Jul 14, 2010 | 08:44 AM
  #45
CLT-tc's Avatar
Originally Posted by draxcaliber
IDK paul, it usually isn't a habit of mine to second guess you, but when i had the TRD supercharger, using the supplied 410 or whatever they were injectors with the 9.5 psi nst pulley, and the TRD reflash, my intake temps would usually only be 10 above ambient air temp. i think the one really hot day i took it to the track it when it was 110 degrees, i don't remember seeing anything higher than 15-20 degrees above ambient air intake temp, and i did 9 runs back to back.
so what did you use to check your air temps?
rain7905643
Jun 13, 2018 05:29 AM
corbinortiz
Oct 2, 2015 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
terrye
Sep 26, 2015 12:24 AM
