TRD Supercharger Thermostat
Old May 22, 2008 | 06:59 AM
TCFROEZEL's Avatar
Default TRD Supercharger Thermostat
hi quick question. would it affect the Supercharger if the Stock thermostat was used ?
and in what way if you guys have experienced any problems.
thanks
Old May 22, 2008 | 07:28 AM
Nick06tC's Avatar
It wont immediatly affect anything. but in the long run it will add wear and tear becuase the car will run warmer.
the thermostat tells the fans when to turn on. the trd thermostat just turns them on 20 degrees colder to increase cooling. I want to say its a 140degree thermostat. Or is it 120??
I reccomend using it tho, heck even for a stock car it would be better.
Old May 22, 2008 | 07:35 AM
TCFROEZEL's Avatar
Uhmn ok ok
thanks NICK.
Old May 22, 2008 | 08:11 AM
toyota_scion_tc's Avatar
The temperature will be lowered like he said but that is inaccurate about the fans, I am not exactly sure on the tc but cars with electric fans have one of the two setups I am going to list. The 1st one the ecu controls the ground on the relay for the fan and when needed it will ground the relay to turn the fan on. The 2nd uses a sensor in the coolant and once the coolant reaches a certain temp depending on the sensor the contact inside is closed grounding the fan relay turning the fan on..
Old May 22, 2008 | 02:53 PM
Buck's Avatar
The thermostat still is the sensor used to decide when the fans need to go on... the TRD one is a lower temp one, and should definitely be used. I am just curious, why do you ask this? Just looking for a quick way to replace a broken one or something? I would think the prices would be about the same.
Old May 22, 2008 | 03:09 PM
The thermostat is not a sensor in anyway. It is basically a temperature valve that opens at the set temp.
Check this link
http://images.search.yahoo.com/image...vpqbkq2&tt=322
Old May 22, 2008 | 03:14 PM
Buck's Avatar
Look, we aren't going to get into the fact that, by it responding to a "change" in the system, that it is a sensor in every way. It is still reccomended to use it for your SC car, and it will still make it run cooler. Thanks for that link.
Old May 22, 2008 | 04:06 PM
A sensor is a device which measures a physical quantity and converts it into a signal which can be read by an observer or by an instrument. In most cases this is done with the ECU or Gauges.
http://en.wikipedia.org/wiki/Sensor
Old May 22, 2008 | 04:08 PM
The thermostat included with the TRD supercharger is a 160 degree and the OEM is 180 degree.
Old May 22, 2008 | 05:11 PM
Scott8's Avatar
wouldn't using the TRD thermostat be a nice add on to any turbo kit?
Old May 22, 2008 | 05:28 PM
Sure would, I acutally bought one a while back and have never installed it. I have a great reason to now.
Old May 22, 2008 | 06:05 PM
Scott8's Avatar
How much it run? did you just go to the dealer and get it???
Old May 22, 2008 | 07:22 PM
I can't remember I got it from trdsparks.com and I think it may have been 50. It was redicoulous whatever it was because I couldn't believe it. There might be a 160 thermostat out by stant now you might want to check would be cheaper.
Old May 22, 2008 | 09:01 PM
TCFROEZEL's Avatar
i asked cause i just wanted to know. i bought a used TRD supercharger kit. and that has been missing so i want to know i could install it and buy on later on without problems .
or buy it and install at once.
Old May 22, 2008 | 09:03 PM
Scott8's Avatar
I would do it all in one shot
Old May 23, 2008 | 06:18 AM
Nick06tC's Avatar
Of course the thermostat doesnt DIRECTLY turn the fans on. But where do you think the ECU gets the temperature reading from????
The thermostat monitors the temperatures. When the temp goes above whatever the thermostat is, it sends a signal to the ECU or the fans, depending on what style setup our cars have. Once the temperature exceeds the thermostat the fans kick on.
So in all ways about it, the thermostat controls the fans.
Old May 23, 2008 | 07:58 AM
http://www.autoshop101.com/forms/h32.pdf
Please read it will do you some good!
Please tell me you don't do your own maintenance!!!
Old May 23, 2008 | 08:38 AM
TCFROEZEL's Avatar
Hey kids quit fighting. We are here to help each oher in the forum.
Old May 23, 2008 | 09:20 AM
Nick06tC's Avatar
I deffinetly did learn something there. thank you.
To your second statement. Come on now, because knowing exactly how a temperature sensor works has ANYTHING to do with knowing how to do maintenance on your vehicle. Get real for a second.
Old May 23, 2008 | 10:49 AM
I was trying to show you the diffrence but its hard to online because working with limited things online. A thermostat holds coolant in the engine until the temprature that the thermostat is rated for is reached and then opens (182 or 183 to be exact on the oem) allowing the coolant to pass through the radiator to cool. I am just stating that you should have at least basic understanding of how the diffrent systems on a vehicle works before trying to repair things that you don't understand.
