Tuning F/IC - Crank / Start Cylcle?
This is just a annoyance of mine... since i went turbo my crank times are like 3-4 seconds and then fires / idles very nicely. Is there something wrong on my map during crank? Too much / too little fuel?
so idle is fine and drives fine righ? it just takes longer to actually turn over? is fuel system still stock? (ex...injectors, fuel pump) If so try turning the key to the on position for about 3-5 secs then start the car. That pretty much lets the car prime for bit allowing the fuel pump to send more fuel to the motor.
My friend had that same issue when he upgraded to the walbro 255 and this is what he does and it starts up right after.
usually a lean mixture while cranking causes extended cranking, try adding some fuel on the low rpm/load area, but ignition plays a part on that too.. but check your plugs if theyre fouled.
try adding fuel below 600 rpm, or check if you are not pulling timing on those area... did it just start doing that or it has been like that since you installed your kit.. fic doesnt have much control on startup so pretty much its more on just playing with your basemap unless its a hardware issue
I have this issue too with F/IC.
New plugs, Walbro 255, 630cc Motron, idles fine and drives fine.. but the crank takes forever. Kind of embarassing too.
I should also add that when I plug in the Unichip it doesn't do this.
My car takes long to start sometimes too. To my understanding, it takes the range of fuel trim boxes from KOEO to idle and averages them out, then uses that average fuel trim to start the car. I haven't found the right trim, but I'm ranging from -64% to -48% throughout the idle/KOEO position (550cc INJ). I have noticed that it seems to take the longest to start just after filling up the car.
I don't notice a change regarding fill-ups. I don't notice a change with regards to temperature either. There's been a big change in temp down here.. from 70's to 50's in the morning and not a difference. Each time takes long. Very embarrassing.
I wonder if anyone's messed with the injector response time? What's everyone else's set to?
key on engine on?
I believe due to our returnless fuel system, and the pressure in the system when the tank is low, blah blah blah.
Cranking is annoying right now, due to the start up fuel/spark I have right now.
I have played around with the injector response time. Its seems to deal with the voltage changes better now. Than with the stock hydra injector latency that was on mine originally.
Mines hit or miss, probobly once a day out of 10 starts do i get a long crank time (5+ seconds) I have tried adding fuel and taking fuel, cant pick it out since its not consistant.
My idle fuel trims are 0 and i also have my entire column under 400 rpms set at 0.... Just hit me that my o2 map might be putting too much fuel at 0 psi <400rpms ... since thats where it sits under crank... hmmm
I have 630cc injectors with Walbro 255 intank
key on engine on?
Sorry, might be a Ford thing...
Originally Posted by paul_dezod
Play with initial crank advance, VVT-i, your ignition maps. These will all effect how the standalone cranks. Plus with the piggybacked cam and crank signals like Hydra, it takes a while for the cam and crank signals to sync up and then the Hydra to see them sync up.
mw1957
03-16-2015 06:00 PM
TheTripleC
01-04-2015 06:46 PM
