tuning question for turbo
Old May 13, 2008 | 04:54 PM
azureloki's Avatar
Default tuning question for turbo
I was wondering if turbo required an anual tuning,
is it a 1 time tune for turbo, or yearly tune
because i heard different stories from people
and the turbo car will mostly be daily driven
Old May 14, 2008 | 10:33 PM
azureloki's Avatar
bump
Old May 14, 2008 | 10:54 PM
draxcaliber's Avatar
it depends on how and what you tune with.
when you tune with a piggyback ecu, you are altering the signals the engine receives to decieve how much air and fuel are actually being put into the cylinder when your boosting it. the problem is that the car's ecu relearns through an A/F sensor in the exhaust manifold that tells it the true a/f ratios, and through that it make corrections, thus reducing the efficiency of your tune.
then, when you tune a car, it is essentially being tuned for the atmospheric conditions at that time. so the car is tuned for that air temperature and that elevation.
so drastic changes in elevation and climate will make the car start running lean or rich depending on when and where it was tuned.
there are solutions, one a standalone EMS that will replace nearly all the functions of the stock ECU. but that is expensive.
less expensive is the AEM F/IC. it has a a/f skewing feature that prevents the ECU from relearning, and then then it also has an onboard MAP sensor, so it tunes off Manifold Absolute Pressure, instead of the MAF sensor.
then there is another way that Garage1217 told me how to do with emanage, but i don't know if he wants me sharing that trick.
Old May 14, 2008 | 11:23 PM
azureloki's Avatar
ahh i see, so i'm guessing your using techniques that will allow you to only tune your turbo for one time right?
Old May 14, 2008 | 11:26 PM
that is how i think it is supposed to work, i haven't actually taken my car in for tuning yet. but that is what i have gathered from reading threads so far.
Old May 14, 2008 | 11:40 PM
azureloki's Avatar
okay thanks for the help
Old May 15, 2008 | 12:55 AM
NVMyTc's Avatar
I had my car tuned in the middle of March, it was around 65*, Perfect A/F all around
recently The temp went up to around 90* and my car started running VERY rich at Wide Open throttle, so I had to go back to my tuners and have him pull some fuel. It only took about 5 Minutes.
So far with my experience is that you will most likely need to get the tune slightly modified as the weather changes.
Old May 15, 2008 | 04:58 AM
azureloki's Avatar
i see how much did it cost u for that 5 minutes?
Old May 15, 2008 | 06:37 PM
08superwhite's Avatar
couldn't you just go into the map and scale the injectors back a little bit to compensate for the temperature. i mean say you are running 550s and you notice that you are running really rich as you said above, couldn't you just scale it down
Old May 15, 2008 | 10:06 PM
Zebman's Avatar
Not that easy. If you "scaled down" the injectors, you'd then be running lean at all other throttle inputs besides WOT, much worse than running rich. Unless you're running rich regardless of throttle input, then you may be able to do that.
Old May 15, 2008 | 10:27 PM
NVMyTc's Avatar
I got it tuned at Churches In Wilmington, and he did the 5 Minutes for free
I suggest you go to Churches for tuning if you do get a turbo.
bootlgr
Jan 26, 2016 01:22 AM
my06tc
Jun 25, 2015 12:18 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
