Tuning the turbo for a "valet mode"
Old Jul 24, 2008 | 05:24 PM
enjoithis's Avatar
Default Tuning the turbo for a "valet mode"
Ok well - my cars going to be in a body shop for about 2 weeks, and i dont want those guys taking my car for "test drives" while its there. I was thinking about cutting the fuel trim back anything over 3krpms so it wont be able to be driven hard.
This should in theory be similar to what we have from the factory at 6200rpms.
Second option was making the waste gate stay open so turbo wont spool up. Of course im not sure about how to do that at this point anyway.
I dont care if the check engine light comes on as a result, as long as my car isnt broken! (its already on anyway)
Is this safe? Any other ideas?
Old Jul 24, 2008 | 05:28 PM
brett561tc's Avatar
you could pull one of the coil packs. it would only be able to move around slowly.
Old Jul 24, 2008 | 05:30 PM
NA_TC_817's Avatar
you can take out the wastegate spring that will keep it from spooling .. but have someone help you hold the top down while your taking the screw out or it will pop at you
Old Jul 24, 2008 | 05:42 PM
Scoobasteve4132's Avatar
Make sure you write down the odometer reading, regardless of which route you take...
Old Jul 24, 2008 | 05:44 PM
enjoithis's Avatar
of course that way i can get them
If i take out the wastegate spring... will it work with my boost controller? They wouldnt know how to program the boost controller to make it boost.
Old Jul 24, 2008 | 05:47 PM
brett561tc's Avatar
just take out a coilpack. its super easy, and i promise you that your car will not be able to rev into boost.
Old Jul 24, 2008 | 05:50 PM
enjoithis's Avatar
that sounds like it might hurt the car.. no spark?
Old Jul 24, 2008 | 05:51 PM
NA_TC_817's Avatar
if they were smart they probably wouldn't want to try to program it and take the risk of doing something wrong just for a joy ride and im guessing its not a manual boost controller so im sure you can disconnect it somehow or you can go with brett's idea
Old Jul 24, 2008 | 05:53 PM
Scott8's Avatar
you can take your car to a body shop you actually trust...
Old Jul 24, 2008 | 05:55 PM
NA_TC_817's Avatar
^^ thats even better
enjoithis's Avatar
I trust the shop to do my repairs but when the boss isnt around people are always tempted to take a car like this for a test drive. I dont think they would but, you never know.
First time going to this shop - the last 2 body shops ive delat with i wasnt happy with their work. so... hopefully all goes well. Just so nervous leaving it..
Old Jul 24, 2008 | 05:56 PM
brett561tc's Avatar
i had to drive my car for several l weeks that way, and its running just fine.
Old Jul 24, 2008 | 05:58 PM
Scott8's Avatar
pull the EFI fuse. They'll have to push the car, but screw them!
Old Jul 24, 2008 | 06:01 PM
enjoithis's Avatar
haha true true..
i like the wastegate idea because i actualy want to run it with my boost controller at lower PSI then the spring, but will that work with no spring?
Old Jul 24, 2008 | 06:30 PM
thendawg's Avatar
If you remove the wastegate spring you will create no boost regardless of the vacuum "signal" to the wastegate, without the wastegate spring it will stay open all the time regardless of boost/vaccum to the port, so without it = no boost.
Old Jul 24, 2008 | 06:43 PM
enjoithis's Avatar
ah, so my theory will not work! i need to buy a 5psi spring
maybe ill yank the coilpack like he said...
Old Jul 24, 2008 | 07:20 PM
yellowxhoodie's Avatar
just take a pic of the odometer and say you know how many miles are on it and if theres a significant amount of miles added when you get the car back your gonna give them hell.
but def. x2 on taking it somewhere where you wouldnt have to worry about this.
Old Jul 24, 2008 | 08:28 PM
Red_tC's Avatar
^yeah it is alot harder to dispute pictures than just writing it down
Old Jul 24, 2008 | 08:37 PM
enjoithis's Avatar
true! good point.
also should take a picutre of how much tread is on my tires lol
im not really that worried about it i just want to be safe lol
Old Jul 24, 2008 | 10:41 PM
aen's Avatar
aen
pull the maf sensor they wont' be able to go into boost aaaaaaaat all.
