turbo for auto tc
Can you guys give me a full list of parts i would need to turbocharge my tc i know you cant just drop a turbo in there can i jsut get a list of parts needed. cars auto
1.) Manual Transmission
2.) Turbo Kit
3.) Clutch kit
Seriously, I'm sure this has been talked about before. I'm almost 100% positive. But you'll need the kit, and a tranny upgrade. You might be able to get away without the tranny upgrade for a while, but you'll probably notice it slip in first and second gears if you put more than probably 250 whp.
2.) Turbo Kit
3.) Clutch kit
yea im tryng to learn about it my friend said i should get e/i/h first then get low pressure pistions and then get the kit that should come with a intercooler and i dont want to switch to a manny trans and for a trans upgrade what should i get for trans. I also understand i need a fuel mangement upgrade anything else?
Your friend's either badly informed, or an idiot. Getting an exhaust, intake, and header would be a substantial waste of money if you're going to turbocharge. Depending on which kit you go with, something get's thrown in the trash:
With a standard kit, like Dezod, ZPI, GReddy, TurboToyotas, Treadstone, or Sound Performance, the intake and header need to be thrown out, since you get an intake and an exhaust manifold with the kit.
If you decide to wait for Stripper's turbo kit, the exhaust and intake will be thrown out, since it's a rear mounted turbo setup.
Either way, it's about $500-$700 wasted.
As for the tranny upgrade, this is the first one which comes to mind:
http://www.zeropointindustries.net/s...roducts_id=237
Other companies may have something similar, but I don't know off hand.
It...depends. If you get a regular "under-hood" turbo kit, an exhaust is always a good idea. If you get a rear-mounted turbo, then a header is always a good idea. It just depends on what needs to be replaced. :D
nvm the dezod comes with intake and exsuast trans cooler and 550cc injectors so i can jsut buy this kit and install everything and i will be fine here a link so you can read it overhttp://www.dezod.com/pd_dezod_motorsports_s1_turbo_systemscion_tc_0506_automatic_transmissions.cfm
https://www.scionlife.com/forums/viewtopic.php?t=140610
read that first any further questions PM me.
ScionLife Editor
Mar 21, 2015 03:10 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
