turbo build help
Old Mar 11, 2011 | 03:36 PM
NYcarbonTC's Avatar
Default turbo build help
whatups guys so i am almsot donw with my turbo build, just wanna make sure i get the right size for my spipe and midpipe. I have an HKS exhaust on right now with the stock spipe and midpipe. I measured the the turbo down pipe and it measure 2.4/5s ( im not sure how to write it but its grater then 2.5) i thought it would be jsut 2.5 but guess not. So my question is should i get a 3 inch spipe and mid pipe or idk and i have to look up for the hks size hopfeully it matches up. let me know wat you guys think i should do
Old Mar 11, 2011 | 05:42 PM
trd07tc's Avatar
the bigger the better
Old Mar 11, 2011 | 08:21 PM
XPRTc's Avatar
In most cases 2.5" will do just fine and you can make good power with it, but reducing back pressure as much as possible is ideal to squeeze out as much HP in the top end as possible. Most people that are boosted will go with 3" from the down pipe back; and the only companies that sell 3" exhaust systems are P-Tuning and Descendant that I can think of otherwise you can just go the custom route.
I know ScionAndrew is trying to get rid of his custom 3" S-pipe back with a cf HKS hi-Power muffler for $200 shipped in the classifieds which is a pretty nasty deal. Just a heads up.
Old Mar 12, 2011 | 02:53 AM
NYcarbonTC's Avatar
arite cool im going to check that out thanks
Old Mar 16, 2011 | 12:48 PM
NYcarbonTC's Avatar
still working on the spipe and down pipe, just gotta get some vacum lines for my gauges but while i was going over my kit last night i also noticed with the wastegate theres another end to it, im not sure what it needs to be bolted up to or it just stays open, its hard to explain but when i get home ill snap a pic of it... im new to the turbo game so any help would be necessary .. thanks
Old Mar 16, 2011 | 01:12 PM
crush02342002's Avatar
wastegate will bolt to manifold, the other end of wastegate you can leave open but your engine bay will look like hell after a while. It will blow carbon all over the place, so its best to have a dump tube fabbed up and ran towards the ground.
as far as vac line for the wastegate you will want to hook a vac line to the bottom port and leave the top port open unless you are running an electronic boost controller that requires both ports to be connected to the controller.
Old Mar 16, 2011 | 03:17 PM
NYcarbonTC's Avatar
thanks a lot crush that was very helpful
Old Mar 16, 2011 | 10:26 PM
not a problem
BlackKnight
Sep 15, 2015 06:42 AM
VitaminE
18
Jul 2, 2015 08:10 PM
AScottE527
Apr 2, 2015 09:40 PM
mav261
Mar 24, 2015 01:19 AM
xa007xa
Feb 22, 2015 03:05 PM
