Turbo install, vacume lines???
About to put my custom kit on in the next few months and need some info on were to run the vac line for my EXTERNAL WASTEGATE. Alot of people are telling me that there should be a connection on the turbo housing, witch i don't have... I know the BOV/BOOST GAUGE plugs up to the vac line on the throttle body( I believe the other lines are for coolant) so i got the dezod vacume block, witch made me assume to hook up everything to that but I'm not to sure...
:Things to hook up:
-External Wastegate
-BOV
-Boost gauge
-Greddy pressure sensor
:Things to hook up:
-External Wastegate
-BOV
-Boost gauge
witch one is best to go with or does it matter? my buddy said that if I connect it to the vac block, it'll take longer to boost and if I hook it up to the turbo housing it'll boost quick...
wrong......if you hook it up to a vac block, youll over boost....best way to hook it up is from turbo strait to wastegate.....buy a vac block and hook your gauge, bov, fpr, etc to it. but your turbo shuold always go strait to wastegate.
it wont boost faster either....what it does is lags the time in which your wastegate opens.....you have more line to go through running it with a block then strait to the turbo...therefore more time to build boost before the wastegate sees it.
Of course, if it was going to the compressor housing, no problems, maybe AFR would be off, rough idle, fix it...In short, turbo housing-->wastegate=safe...
gingles is correct, best thing to do is run your vac line from the turbo directly to the wastegate.
If you had an FIC the best way to source that is directly to the brake booster.
Everything else can use a vac block with the throttle body vac line being the source.
/thread
/thread
I had the same exact questions as the OP, and after searching a lot, and asking a lot of questions from the pros, here's a diagram i put together. Hope it helps and maybe others can find it useful as well. Also if something looks like it needs to be changed please chime in and let me know. If your turbo compressor housing did not come with a barb fitting, you can tap one in no problem... or you can tap one in on the intercooler piping right under the coupling that joins the pipe to the turbo compressor outlet.
Our plastic manifold is actually really strong.. I made just under 350 whp before i got rid of my scion on the plastic intake manifold.. and i did drill a hole in it to supply vaccum to my boost gauge, BOV, pressure sensor, and wastegate.
i never said it wasnt a bad place for one.......yes having vac ports in the intake manifold is one of the best, again i didnt say it wasnt. and yes we all know it can hold well over 350hp......i just dont see how drilling it is a good idea when you can use the brake booster line for your vac source.
