Turbo Problem
Old Jun 19, 2008 | 10:53 PM
tCtCtC's Avatar
Default Turbo Problem
Alright, this has been going on for about 2 months now.
Mods are ZPI Stage 0, 1 step colder spark plugs, HKS SSQV, and full exhaust.
Here's the problem. When I run in full boost (6 PSI) I start to get a good amount of white/blue smoke. It's not pure blue, its only a very light tint of blue. At first I thought it was my oil return line so I had it replaced for a stainless one. Still have the problem. The previous owner had no problems like this as all. There's no smoke when I run it below 5 PSI. I have to run it in 5-6 PSI for atleast 10 seconds for it to show up. There's no oil in the charge pipes, my coolant and oil levels are fine, no smoke coming from the turbo, no smoke at idle, no exhaust leaks, no oil leaks, no abnormal oil coming from the breather, the turbo was cleaned and rebuilt before it was installed by turbochargers.com and there was no shaft play. This only started happening recently. The only problem I can think of right now is TUNE. My biggest fail yet. I don't have an AFR gauge yet, but judging by the exhaust smoke I'm not running rich. My idles have been fine, no compressor surge at all. I do stall after the BOV goes off and i come to a stop, but many 07's have that problem and I might be getting a new BOV soon.
Any suggestions?
Old Jun 19, 2008 | 10:57 PM
2_much_tc's Avatar
Even though I don't own a turbo, I'm gonna say the Tuning. You should know by reading the numerous threads that tuning is a must... But I know this doesn't help you. GL...
tainoxl's Avatar
Compression test, possible head gasket, Runing super rich under boost, i would do a compression test and get tuned
Old Jun 19, 2008 | 11:01 PM
tCtCtC's Avatar
if it was a head gasket, wouldnt there be smoke coming out no matter what PSI or RPM?
Old Jun 19, 2008 | 11:02 PM
B_Real45's Avatar
Very good advice. A compression tester is a must have for a turbo owner.
If you have lower than normal compression (which I'm not sure what it is on our 2AZ but I'm guessing around 220psi per cyl) but all the numbers are the same, it could very well be your headgasket. If you have a drastically lower number on one of your cylinders then the ringlands could be broken or have worn rings.
Is there a distinct smell to the smoke? Can you smell coolant?
Old Jun 19, 2008 | 11:03 PM
BuddhasTC's Avatar
also the "stalling" could be from a vaccum leak, check the hose...and get that thing tuned
B_Real45's Avatar
Depends on the severity of it.
Old Jun 19, 2008 | 11:04 PM
tCtCtC's Avatar
Theres no abnormal smells at all.
and i believe the compression should be around 180 - 190, so ill do that.
Old Jun 19, 2008 | 11:05 PM
tCtCtC's Avatar
all vacuum hoses are fine
Old Jun 19, 2008 | 11:09 PM
java09's Avatar
sounds like the seals on the turbine are going out to me...
Old Jun 19, 2008 | 11:11 PM
java09's Avatar
even though you say it was recently rebuilt maybe there messed up while doing it.. pull the intake pipe off and check for oil. sorry to hear this bro. also check inside coolant over flow tank for oil or if its merky...
aen's Avatar
aen
first
you need a afr gauge, you should have gotten that in the first place
that would tell you if you are running rich, if you were running rich that would explain the smoke.
i had smoke when i was running rich, it's probably because when you upped the boost hte tune wasn't meant for that high of a boost so it goes rich and produces smoke...the tint of blue is probably your imagination, if it was tinted blue it would be coolant/water and would be leaking from the begining at idle
Old Jun 19, 2008 | 11:14 PM
tCtCtC's Avatar
this is going to be such a noob question, but can you replace turbo seals?
aen's Avatar
aen
wait nevermind, i just remembered that i was producing smoke because i had a tiny kink in my oil line.
negate what i just said lol.
B_Real45's Avatar
Aen,
Blue = oil
White = coolant
Black = gas
Old Jun 19, 2008 | 11:16 PM
aen's Avatar
aen
Originally Posted by B_Real45
Aen,
Blue = oil
White = coolant
Black = gas
i know, i just woke up =P
aen's Avatar
aen
yup, it's not that hard...just buy the seals take it apart and you'll see the seals
but if it was hte seals you'd be making smoke at idle if i recall correctly
Old Jun 19, 2008 | 11:17 PM
tCtCtC's Avatar
no oil inside the intake pipes. no oil in the coolant tank
Old Jun 19, 2008 | 11:19 PM
tCtCtC's Avatar
or at any PSI for that matter. when i rev at theres no smoke coming at all. its only at 5-6
and where would i be able to find turbo seals if it is that?
B_Real45's Avatar
Just do the compression test first.
See what that tells you.
Then buy a wideband AF gauge - and see what your mixture is during WOT at 6psi. And compare that with whatever psi you were running to not produce the smoke.
