Turbo Woes
Ok heres the rundown.
I just bought a turbonetics kit for my tc.
Ok sweet it comes with a T3/T04 E-50 Ball bearing turbo.
Aswome however it wont do the trick of getting me to my 300 whp goals.
So i need a slightly bigger turbo. 57 trim ball bearing, GP 30 or somthing. Yeah i dunno thats what my tuner said, i know i know its because i live at high alititude. Well does anyone have any solutions like does anyone know of any companys that exchange turbos or someone that needs a T3/T04 E-50 Ball bearing turbo, im willing to sell mine.
Thanks guys!
Thanks guys!
David huh? LOL, anyway, I made 259WHP and 287WTQ at 8 lbs with a ITS T04E-60 .63 A/R turbo. What wastegate spring are you using? You need 12 psi on that turbo to get to 300WHP if lucky. Plus, get a 3" exhaust, that will give you more power also.
you need a tubular manifold to get great numbers at low psi. i made 315whp on 10 psi with a precision 3431RE turbo, which is basically a t3/t4 50 trim. prescision turbo website has all the specs. full boost at under 3500 rpms, i think around 3200, its been a month and a half since ive been without turbo due to rebuild.
Are you serious???
The T04E 50 trim will get you 300whp easy.
I got 272whp at 9psi with the UNICHIP... now I'm tuning my F/IC and It'll be more - assuming my engine is still okay.
Your turbo is fine - quit wasting money on a larger turbo and invest it in a good tuner.
Uhh yeah ok i figured as much that the kit advertises hp to the crank not to the wheel, however i do live at higher altitude i live in colorado springs. I think what tcdude said sounds more correct. Thanks fellas this has been fairly enlightening.
Alot of the 'numbers' depends on what kind of dyno you used. You may be on a more conservative dyno.
I dynoed 254 whp and 267 wtq on Ptuing's dyno, which has a very conservative reading compared to other dynos. Compared to other people's dyno numbers, it seems on the lower side, but that doesn't mean it's not fast (I just spin the wheels in first and second when I get on it).
I wouldn't get to hung up on the numbers, but rather focus on how it feels. Does it have enough power to keep you happy?
If it does, no action required. If it doesn't take a look into some of the options above. I would highly recommend PTuning's turbo back exhaust. Also, in addition to some of the above, you might want to take a look into water meth. I think Ptuning sells a kit for that as well.
The turbo you have will get you the power you want.
There is no need to spend more money and buy a bigger turbo.
All your doing is trading a larger amount of airflow at less psi by going bigger.
Just start turning up the boost in small increments.
Post all your details and we(the community) can help you out and at the same time save you some money.
What are you making now?
What psi?
Regards-
Todd
What psi?
Regards-
Todd
I already tried giving that advice, Todd.. unfortunately my advice doesn't accomodate the need for a larger e-peen so therefore the advice was rejected.
How are things going anyhow, Todd?
Originally Posted by B_Real45
Are you serious???
Some guy runs 375WHP stock engine. Like we talked about, sell the Turbonetics kit and get a Dezod one. Because Dezod is here all the time helping us and their customer service is great. Turbonetics discontinued their kits I think, so obviously, there is a reason for it.
Memback already has a kit, there is no reason to sell it to by someone else's.
Try actually helping each other out.
Even if he had another companies turbo kit, it doesn't change his problems.
1. He is dealing with Tuners that obviously have no clue.
Memback-
Just some advice based on what you have posted.
Tuner #1 : The one that told you to change turbo: Stay far away from. He obviously is not that familiar with turbos.
Tuner #2: The one that said you need to build your motor to make 300whp. He has no clue about the TC and is looking for more room for error= built motor. Stay even farther away from this one.
You do have more options in Colorado. Just keep doing what your doing. Ask questions. Never be affraid to ask them as many times as it takes for you to feel comfortable with the answer.
And if you talk to any tuner, and you tell him your goal is "x" amount of power a good answer will be " I do not tune for power, but for driveability and reliablity" we will see what your car makes and go from there. No reputable tuner will ever guarantee a power number.
Good luck and keep posting.
Regards-
Todd
i have a t3/ to4e 60 ar cold 82 ar hot. its brand new never been ran. I would be glad to trade you if yours is brand new also. let me know. I am looking for something around ur size . hit me up for pics and what not.
