Turbo XS RFL blow off valve question
do any of you run this bov on your setup and if so how do you like it? i heard one today on a subaru wrx and it did not flutter even once so im wondering if it will flutter on my tc? also i have found an adaptor plate to allow the turbo xs to mount to the hks "ssv" mount. is the ssqv the same thing as the ssv?
here is the link to the adaptor plate
http://www.turboxs.com/shop_prod.php?what_category=5
Originally Posted by tCrew_R
the fluttering sound is most likely the HKS SSQV.
What do you have now?
i want a whoosh all the time, the fluttering sounds retarded.. when i stomp the gas at full boost yes usually i get the full on whoosh. i want a low boost woosh as well. my buddy's wrx does it with that bov even at 1psi.
Large turbos on low boost will flutter under less than WOT conditions. It's just the characteristics of the turbo. Small turbo's don't flutter much at all hence the WRX sounding that way.
It will still probably flutter less than the HKS or TiAL but by how much I can't say.
Originally Posted by krazylowgsx
the "flutter" sound is called compressor surge! there isn't enough vacume to open the bov, so the air backfeeds to the turbine wheel..
Originally Posted by pollup
any way you could make a video with it blowing off? my car usually flutters, sometimes it gives the nice whoosh.
bootlgr
Jan 26, 2016 01:22 AM
