Turbonetics Turbo Install (B_Real45) Update 6/12/09
Originally Posted by TCpete
yea the turbo is a nice sized turbo spools fast and has nice response.. the unichip is the largest downfall... if u crossed over u'd be alot happier with the fic then the unichip to reach your goal.
Funny - a member on here with built internals and the T'netics kit, and a Motec EMS made 443whp at 20-something psi.. this was with the supplied turbo from T'netics.
I'm looking for 300whp with a quick response - I think this turbo will fit the bill just fine.
Maybe eventually I'll grab a GT3076 but that's way down the line.
Are you guys serious?
The guy is legit.. he has one of the best engine management solutions on the market in the tc
His thread is on here.. search for "turbonetics dyno"
here's the video:
http://m.youtube.com/watch?desktop_u...le&gl=US&hl=en
here's the video:
Yeah I've been back and forth with Tnetics about it. I've tried a couple of Unichip units they've sent me. All the same.
I think it may be my primary O2 sensor...
T'netics said I should be even richer cuz I'm in Miami (hotter weather - before dyno was in 90+deg) at sea-level, and I'm using 93 oct when they tuned the car on 91 oct.
B_Real, I was scanning back through your pics, and I came upon this pic of the Radiator cap and safety chain.
Speaking from experience here, that chain being screwed into that bolt could be causing electrical interruption with your car. I had mine the same exact way, and when I mashed the gas hard, my ignition fuse would blow. I went through 2 - 3 fuses before realizing that my slim line fan being connected to the ignition was getting a current interruption because it was attached to the Mishimoto, which was attached via that chain to a bolt in the chassis (which is grounding out the current). I'm not saying that this is the cause of your 02 sensor voltage or anything, but it does not hurt to try and remove the chain to see if it eliminates your problem. I also notice that my A/F ratio changed when I removed that chain from the bolt, so monitor your A/F for any signs of change.
Paul,
I do have an OBDII Scanner - Innovate's OT-1 tool. But the Unichip alters the signals after the ECU, would this tool be useless in monitoring the O2 output?
Rhythm,
I guess it wouldn't hurt to try. I haven't blown any fuses yet. But I'll go remove it now and see if the AFRs are still the same. Btw, I don't think anything is grounded to that bolt..
Rhythm,
