turbonetics turbo option
Old Apr 11, 2008 | 04:57 PM
coryjames's Avatar
garabaldy sounds like you need to invest in a vacuum block from turbo toyotas
Old Apr 11, 2008 | 05:17 PM
garabaldy's Avatar
you are correct sir.........
Old Apr 11, 2008 | 05:20 PM
coryjames's Avatar
hmmmm maybe todd will give me to on a mistake lol how hard was it to do the water meth injection
Old Apr 11, 2008 | 05:46 PM
garabaldy's Avatar
the hardest part was tapping the washer fluid tank, the rest was not difficult. I had a fabricator weld a 1 inch square 1/8 inch thick plate on the I/C pipe about 6 inches from the TB so I had more material to drill and tap for the nozzle.
Old Apr 11, 2008 | 05:48 PM
coryjames's Avatar
thats cool you runing windsheild fluid or actually mixing it up right and how much did it help out
Old Apr 11, 2008 | 10:02 PM
kirk212's Avatar
Can you please tell me what turbo you purchased? Were the AFR's still ok or did you have to re-tune? Great numbers, must feel great.
I went with the Street Heat 50 trim, .48 a/r stage 3 . The AFRs went a little richer after the install, but I noticed there was alot less lag than the turbonetics turno. I waited for my clutch and flywheel to be installed before I got tuned.... maybe a month. But after the tune, a +21whp and +45wtq increase. The car feels pretty awesome.
Paul the exhaust set up is: Megan s-pipe, Megan mid-pipe, Greddy SP2 rear.
By the way this is all at 8.5psi . Im pretty happy with those numbers considering the level of boost. And it was done on a dyno dynamic which tends to be a little lower than say a dyno jet.
Old Apr 14, 2008 | 12:48 PM
tcengel's Avatar
Wow, those are amazing numbers on a dyno dynamics. That's ~300 whp ~350TQ on a dyno jet. Congrats, you must really need an lsd now.
Old Apr 15, 2008 | 03:56 PM
kirk212's Avatar
yea I could def use one. you wanna buy me one bc Im all out of $. Taking corners under a half way decent amount of acceleration can feel pretty rough.
Old Apr 15, 2008 | 04:10 PM
paul_dezod's Avatar
Scionetics
KAD
AHHHHHHHHHH. Good choice for sure. Glad to see she was doing you well.
I did want to tell you to consider our exhaust or something like the P-tuning even. You have some exhaust restriction for sure, and can get even more power from that set-up.
Old Apr 17, 2008 | 04:50 PM
kirk212's Avatar
I know I could get more power with a less restricting exhaust, but Im happy withwhat I have. I drive this car everyday and Im not looking for something thats going to give me a headache after 30 min of driving. The sound is clear, deep, never raspy and sounds great under WOT. I think keeping what I have is worth the 5-10hp I might be loosing.
Old Apr 17, 2008 | 08:06 PM
paul_dezod's Avatar
Scionetics
KAD
Ok. Glad your happy with the upgrade though.
Old Mar 4, 2009 | 03:32 AM
StreetStarsTc's Avatar
hmmm i really need to figure out what i'm doing with my turbo set-up.
some shaft play and i don't know if its worth rebuilding my turobnetics kit or getting a new turbo.
i'm also doing a manual swap, i have everything minus a clutch and axle, i also have a trd lsd waiting to be installed
k1114
43
Mar 1, 2023 03:08 AM
Dbonehead6
May 28, 2015 12:15 AM
B_Real45
Feb 23, 2015 07:33 PM
Ramroids55
Jan 16, 2015 02:42 PM
