Turbonetics wastegate opening at idle
Old Nov 20, 2007 | 04:40 PM
tcengel's Avatar
Default Turbonetics wastegate opening at idle
I have a small leak in the dump tube of my Turbonetics kit. If I hold my hand next to it I can feel a leak pretty strongly at idle. Should there be any air going through the wastgate at idle? I thought this was odd and I should ask.
I also think the turbo spools up kind of slow. At like 30% throttle I am still in vaccum and everyone here says they have part throttle full boost issues. I'm starting to think that I have an issue with the wastegate.
I dynoed ok at 250whp, but that was a Dynopak which supposedly runs kind of high.
I also get a ton of backfires at part throttle which may be normal, but could also mean that it's running rich because the turbos not spooling fast enough.
Any opinions or thoughts on how I could test this?
Old Nov 20, 2007 | 04:43 PM
Guru's Avatar
Check your vacuum lines. Sounds like you have them hooked up wrong. Otherwise I think oyu have a defective gate. Pretty common with the Turbonetics gates.
Old Nov 20, 2007 | 05:08 PM
tcengel's Avatar
Vacuum lines are set-up correctly. Right from the nipple on the turbo to the wastegate. I still get ~8PSI and it doesn't spike or creep.
Old Nov 20, 2007 | 09:13 PM
Guru's Avatar
Then you have an internal problem. Send back to Turbonetics.
bigAL
Mar 19, 2018 06:00 AM
BlackKnight
Sep 15, 2015 06:42 AM
skruff
12
May 28, 2015 03:00 AM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
