white smoke coming out!!!
Old 02-07-2010, 05:43 PM
Dkfung88's Avatar
Originally Posted by deathbyc4
the valve cover has two ports, one on the driver side and one on the back going to a PCV valve to the intake. make sure those arent kinked in any way, then check the driver side port to make usre its not blow out air/oil/water/small animals when at idle.
that explains the quacking sound... i'll take another look at it after the weekends are over
Dkfung88 is offline
Old 02-08-2010, 12:20 AM
tCing_U's Avatar
is my Goodyear 5/8 300psi good enough for return line?
tCing_U is offline
Old 02-08-2010, 07:31 AM
Dkfung88's Avatar
well if -10 is half an inch, then yes 5/8 is good enough
Dkfung88 is offline
Old 02-08-2010, 12:12 PM
crush02342002's Avatar
5/8th ID should be good
crush02342002 is offline
Old 02-08-2010, 12:58 PM
ElevationTC's Avatar
So is this fixed now?
ElevationTC is offline
Old 02-09-2010, 04:11 AM
Dkfung88's Avatar
unfortunately, i think the turbo seals blew.... we took it out, hit 6 lbs of boost or so, and a bunch of white smoke came out of the exhaust... we also smelled something burning... we took a look and saw smoke coming out of the turbo itself... what im wondering is, im using a forge boost controller but when i turned it all the way down, it spiked to 16 lbs... how many turns is 1 psi on that boost controller?
Dkfung88 is offline
Old 02-09-2010, 06:10 AM
sounds like you went the wrong way on the boost controller or you have a pinched (loose) vac line going to the wastegate.
do you have any pics or vid to show us? like to get a better idea of whats going on here.
Old 02-12-2010, 06:07 AM
Dkfung88's Avatar
sorry for the delay guys... midterms come in the worst weeks... but anywho.. heres a few pictures with my camera phone.. i hope u guys can make out what it is
Heres my oil return:
Oil feed:
Turbo setup
Dkfung88 is offline
Old 02-12-2010, 06:12 AM
Dkfung88's Avatar
oh also, i am getting a crankshaft light using the aem f/ic... the only thing i can think of are the confusing crankshaft/cam wires... i tried looking at the diagram they supplied on SL but still confusing.. can somebody clarify this for me on what goes to what?
Dkfung88 is offline
Old 02-12-2010, 10:08 AM
Ronin Scion
Ace83's Avatar
your oil lines look ok
Ace83 is offline
Old 02-13-2010, 08:55 PM
Dkfung88's Avatar
hmm.... i wonder why its still smoking... i hope its not my piston rings >_<
Dkfung88 is offline
Old 02-13-2010, 09:01 PM
In the pic you posted theres oil sitting in the turbo..
Looks like u have a bad turblow
Old 02-13-2010, 10:36 PM
Team ScionTific
Tc4Eva's Avatar
On the oil return line, it kinda looks as if the fitting is sitting at a lightly lower angle compared to the fitting on the pan. I dont have a turbo, and I think you already checked, but make sure that the line does not have any low spots on the return.
Tc4Eva is offline
Old 02-14-2010, 12:26 AM
good eye...i didnt see it..lol
seals and bearings could be damaged...you can check by grabbing the shaft and moving it, if it clicks, makes a noise, or if you try and turn it while pulling up on the shaft and you hear the wheels scratching then you have too much shaft play. BTW i cant make this sound less dirty, its just the way it is.
Old 02-14-2010, 12:30 AM
Thank you..
Old 02-14-2010, 12:51 AM
Welcome....lol
Old 02-14-2010, 07:13 AM
Dkfung88's Avatar
yeah thats just another turbo we used to check to see if my own turbo was smoking... but both of them were smoking and smelled like oil/burning smell.....
tc4eva: wouldnt it still push the oil down even if theres a low spot? cause isnt there oil pressure pushing it back to the oil pan?
Dkfung88 is offline
Old 02-14-2010, 08:08 AM
it is not suppose to work that way. it needs to have no restrictions what so ever. on some turbo kits for say a 350z uses a scavenging pump cause the turbo sits lower than the oil pan. The seals on a turbo just cant take it.
Old 02-14-2010, 08:10 AM
do you know what your oil pressure is?
Old 02-14-2010, 01:16 PM
Ronin Scion
Ace83's Avatar
it doesnt seem that there is a low spot on the oil return.. should be a bad turbo
Ace83 is offline
Quick Reply: white smoke coming out!!!
