white smoke coming out from exhaust after turbo! HELP!
#41
holy crap, i havn't seen a response about the return line yet!
dude, before you go crazy and get all scared and stuff, let us see the kit, a picture of everything, expecially the return line
lost cyl, head gasket, all that crap would have other signs than just oil comming out the exhaust
your turbo seals or your return line is at fault, sometimes hte turbos aren't clocked properly and the returnline kinks, or bends the wrong way, causing oil not to flow properly and as pressure builds, the oil shoots out the seals and into the exhaust, effectively burning and causing white smoke.
#42
alright, i'll check the return line in a sec. One day i saw a small leak of oil coming out of the turbo on the side where the downpipe connects to. Is that a sign of a blown seal? Also, is that why oil shoots out of the exhaust?
#43
Originally Posted by B_Real45
Please drain your oil and tell us if it's frothy - if it is, that means coolant is mixing with oil, so you probably have a broken head gasket.
I drained the oil out to see, it seems normal. just a couple bubbles, does that mean anything? i dont know much about this...
#46
ill bet you anything you THINK it's white, but it's actually grey or blueish white.
it's very hard to tell the difference. frothy is like a rootbeer float frothy, not a couple bubbles. you're fine, there's either a blown seal or a kinked line. no biggy.
car isn't going to blow up
#47
i bet its a blown turbo. i remember it taking me a while to boost (maybe around 4,500rpm) that was after i had smoke. and i saw some videos of blown turbos on youtube, seems like the kind of smoke i have is like those. If its a blown turbo, i can ship it back to turbonetics and have it replaced cause of the warrenty. =D
#48
Yea - when i blew my ring I had a ton of smoke comming out. It would start then stop ....car wouldnt stay running toward the end .... My compression test came out horrible so it was pretty easy to tell the engine was blown.
#49
#50
#51
Originally Posted by rozz-tC
Originally Posted by thendawg
Wether the seals on the turbo are bad or not - if you have a serious case of blowby it will cause oil to go through the seals rather than drain back into the pan
my06tc
06-25-2015 12:18 AM
JM Auto Racing
12-19-2014 06:36 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
ScionLife Editor
11-25-2014 03:00 PM
