wideband o2 bung placement on spipe
Old Feb 7, 2008 | 09:45 PM
TCpete's Avatar
Default wideband o2 bung placement on spipe
k. so ive got an invidia spipe(for now) and im basically prepping the car for boost
so for any of you boost guys... can you tell me were along the spipe you guys have put your wideband bungs on?
here is a sample spipe
much abliged...
Old Feb 7, 2008 | 09:52 PM
Simplyscion's Avatar
Team No Limitz
about 4 inches to the right of the original sensor bung...on the straight pipe section
Old Feb 7, 2008 | 09:55 PM
jrodTc's Avatar
I put mine here:
Edit: Oops, this should work
Old Feb 7, 2008 | 11:01 PM
2_much_tc's Avatar
it supposed to be a few inches after the first 02 sensor...
Old Feb 7, 2008 | 11:38 PM
Scott8's Avatar
The instructions with your wideband will tell you how far away from the block the sensor should be. I think my AEM was 18-24 inches from the block, so mine sits about 3-4 inches from the current bung for the 2nd o2 sensor
Old Feb 7, 2008 | 11:40 PM
TCpete's Avatar
lol k so we got 2 conflicting views and 1 picture that doesnt work lol... bust out your mspaint skills and mark the pipe lol..
Old Feb 7, 2008 | 11:43 PM
TCpete's Avatar
is that on a stock spipe or aftermarket?
Old Feb 7, 2008 | 11:48 PM
Scott8's Avatar
mine is aftermarket
Old Feb 7, 2008 | 11:50 PM
caveman's Avatar
1UP Crew
Team No Limitz
it wont matter...go with about 4 inches from the current bung like everyone has said so far and your good. Do it about an inch after the curve away from the original bung on the s pipe where its at its most straight point so you dont get turbulent readings.
Old Feb 7, 2008 | 11:54 PM
Butane's Avatar
it's 18" from the turbo and not after a cat.
Old Feb 7, 2008 | 11:58 PM
BrownDogg's Avatar
Put it about an inch or so after the 02 bung thats already there. Thats how the Dezod spipes come.
Old Feb 8, 2008 | 12:39 AM
jasonrs2's Avatar
1UP Crew
i read in a few places that it goes about 3 inches before the exhaust tip.
(jk)
Old Feb 8, 2008 | 12:47 AM
BrownDogg's Avatar
haha HELLLL NO. It goes on the S-pipe for sure.
Old Feb 8, 2008 | 01:36 AM
ippskidder's Avatar
1UP Crew
(jk)
Maybe your thinking about the flamethrower kit.
Old Feb 8, 2008 | 02:26 AM
rhythmnsmoke's Avatar
Music City Scions
+1 Which would be the downpipe, instead of the S-pipe.
Old Feb 8, 2008 | 02:34 AM
Crippie's Avatar
1UP Crew
what if it were about an inch or two from the connection between the down pipe and the spipe?
Old Feb 8, 2008 | 02:42 AM
Music City Scions
Thought I would do a google search on where to place a wideband sensor and came across one site that said:
On turbocharged engines the UEGO sensor must be installed after the turbo charger, if not, the pressure differential will greatly effect the accuracy of the unit. In applications with a catalytic converter, the UEGO sensor must be mounted BEFORE the converter. In applications with an auxiliary air pump, the UEGO sensor must be mounted BEFORE the pump input to the exhaust stream. Installation angle should be inclined at least 10° towards horizontal (electrical connection upwards, see diagram) which prevents the collection of liquids between sensor housing and sensor element during the cold start phase.
Old Feb 8, 2008 | 02:43 AM
Crippie's Avatar
1UP Crew
great find
Old Feb 8, 2008 | 05:05 AM
Mr_Meaty's Avatar
Mine is a couple inches after the 02 sensor.
