ZPI kit question
Here are some pics of my setup. Not a show car. This is my daily driver weekend warrior(AX). I would recommended a lightweight crank pulley. It seems to help at idle and on launches. I just picked up a TruBoost and plan on going up a few PSI this spring. I am running just under 6 PSI right now.
Engine/Drivetrain Modifications: ZPI Turbo Kit, IC Piping, Synapse BOV, Motor Mounts, Greddy Blue tuned by ESP in Mass, Denso 550 Injectors, Ptuning 3" Axle-back, Light Weight Crank Pulley, Suspension Modifications: Hotchkis front and rear sway bars and braces. TRD Shocks with Votgland Springs, Ingalls Rear Strut Brace, Stainless Steel Brake Lines
Sent From My Mytouch 4G
On a Mustang Dyno I put down 211HP/236TQ. That was before the Ptunning exhaust, new BOV, and the pulley. Not sue what I am getting now. Need to go back and find out soon!
Pretty good numbers for Mustang Dyno with only 5.5 PSI... well I think they are :D
There is alot of good info in this thread i am intrested in going tuboed this helps out with some my questions.
ALSO ARE ANY OF YALL LOOKING TO SELL YOUR ZPI KIT?
IF SO PM ME OR EMAIL ME ARYANA159@YAHOO.COM
yeah 5.8psi i think u can make more though not bad i think u can make a bit more on 5.8 but hey its a start
Don't know if this has been done. But I don't like the j pipe on the set up so my question is can you change the position of the turbo compressor housing. Instead of facing up can you change it to facing down instead.
yes i've changed the posisiton before most of us have it's called "clocking" a turbo. you would probably have to have a new lower charge pipe made but i'm sure it's possible
