06 Scion tC Windows won't work.
Old Nov 11, 2011 | 05:04 AM
jburgess56's Avatar
Default 06 Scion tC Windows won't work.
Had to change my battery and afterwards the passenger window will not roll up or down using the drivers side window switch.
The passenger side window switch will roll it up or down.
Is there something to reset after changing the battery?
Thx for helping! ....:>))
Old Nov 11, 2011 | 06:46 AM
Vulkinator's Avatar
Should say in your owners manual. Just hold down the passenger button to roll the window all the way down and then hold it to roll it all the way up and hold it for a few seconds after it's closed. That should fix it. You have to reset a couple things after you disconnect the battery. TRY USING THE SEARCH FUNCTION NEXT TIME.
Old Nov 11, 2011 | 11:19 AM
criminaltc's Avatar
Yeah, this needs to be closed. Talked about and explained clearly in others. This guy is right though. Roll both windows all the way down. Roll them up at the same time and after they are all the way up, continue to hold them up for 5 seconds. The windows will now work just fine. But this guy above failed to tell you about the sunroof. It needs resetting as well. Do the same thing. Open it fully, then close it all the way and continue to hold the button for 5 seconds. Then your sunroof will be good as well.
daniinpitt
Apr 4, 2015 08:07 PM
IrjI619
Dec 21, 2014 05:04 AM
minter66
Dec 15, 2014 01:45 PM
pier0723
Scion tC 1G ICE & Interior
Dec 3, 2014 03:38 PM
Joeynenj
Nov 25, 2014 05:29 AM
