1 or 2 subs for SQ?
Originally Posted by SCI_TC_GUY
^^ speakers should be set with an o-scope, but often times if you set a sub gain with the o-scope as well, the substage will be overpowering the front mids/highs that are amped... you should set the mids/highs gain with the o-scope to their loudest/cleanest point then set the sub gain by o-scope as well but then turn it down untill it's balanced with the mids/highs will prove to be the best option
Originally Posted by trialsindude
I have one sub and just got metered with a TL mic and hit 139db at 42Hz. So theres no need for 2 sub, 1 is where its at....
stereo would be pretty pointless... anything < ~80Hz is omnidirectional anyway... can't tell where it's coming from musically speaking...
The solution is to crossover no higher than 60Hz, using 24dB/Oct attenuation, with midbass speakers in front that are flat down to at least 60Hz. This way you can acheive the illusion of "up front bass".
Regarding stereo versus mono, it depends on the source media and how it was engineered. Many recordings do place low frequencies on both channels with equal amplitude, such taht they're effectively mono, However, there are still many recording made (jazz, classical, etc), where certain low frequency instruments are only placed on one channel, such as when a stand-up bass is on the right side of the stage. The point is, if you're really serious about SQ, such that you want your system to perform optimally on all types of music, stereo subs are better than mono.
Since the illusion of up front bass is a large part of SQ, having a midbass up front with xovers on the substage set as said, it wouldn't matter whether you have 1 sub mono or 2 in stereo/mono because you'd get the imaging of that stand up bass through the midbass with the "heart" of it coming through the subs omnidirectionally.... only way you "know" the subs are back there is because of clues such as panel rattles, turbulence from a corner fired enclosure, etc...
doesn't really matter... agree to disagree I suppose....
BlingSlade
Oct 19, 2016 12:39 AM
umnitza
Sep 1, 2015 08:06 PM
