10" subwoof question
Old Mar 18, 2007 | 06:03 PM
Robs07Tc's Avatar
Default 10" subwoof question
Alright this is a question i need answered. I have the 100watt 10" bazooka sub woofer so i was wondering if i put in a new 10" 600watt sub woofer in to replace it will it be able to be powered by the car? Because i wont be able to buy a amp for about 3-4 months after i purchase a sub. If the scion can hand it for a couple months or even if it can handle it a lot.
Old Mar 18, 2007 | 06:13 PM
suvving's Avatar
if you've got the bazooka sub that you can order with the car, it has a built-in amp. That means you'd need to get a new amp to power a new subwoofer. It's possible to run your subwoofer from the factory head unit, but it won't carry enough power to sound good.
Old Mar 18, 2007 | 06:21 PM
Robs07Tc's Avatar
eh. i'll just save up for a new box/amp/subs then.
Old Mar 18, 2007 | 06:31 PM
StealthScion's Avatar
no. no its not. [possible to run an aftermarket sub off the factory head unit with no amp]
i don't know much about the POS factory sub, but it sounds like you will need a new amp and box too. probably also a amp wiring kit, because i'm not sure how the factory sub system is wired, but i not sure if you'd be able to tap into it (power, remote, rca) or not.
you can find them [audio equipment] cheap. check craigslist.com in your area, etc...
Old Mar 18, 2007 | 06:34 PM
Yanki01's Avatar
save your money and do it right!
Old Mar 18, 2007 | 06:46 PM
suvving's Avatar
If he's got the line, power, and ground wired to the rear for his existing amp/sub, he can hook those up to a new amp. It IS possible to run a sub off the headunit speaker-level out, but with the low wattage running back there, the sub won't do much.
Obviously the best way to go would be to get a new amp/box for his sub, but is it POSSIBLE to run an aftermarket sub off the factory head unit without an external amp? yes.
Old Mar 18, 2007 | 06:57 PM
Robs07Tc's Avatar
alright ill save up for the i.c.e. later then.
Old Mar 18, 2007 | 09:26 PM
RyanK's Avatar
you guys are nuts. Don't bother running a subwoofer without an amp, it won't do what it's intended to. His initial question was if he could replace the sub in the bazooka tube. .....I doubt it. The sub is probably not simply screwed into the enclosure, and you'd probably need to modify it so the new sub will attach. I've gotta assume too that the sub in the tube is most likely the best component for the included amp.
Old Mar 18, 2007 | 09:35 PM
Yanki01's Avatar
will an aftermarket sub fit.......YES!
https://www.scionlife.com/forums/vie...121308&start=0
Old Mar 19, 2007 | 02:57 AM
RyanK's Avatar
You can certainly do that. I'm not trying to be a know-it-all, but I was aware of using the sub wiring to run a seperate amp. I guess I was thinking he was trying to just replace the sub, and have the replacement sub powered off of the existing Bazooka amplifier. I think I'm gonna check the Bazooka out more thoroughly before I post something that has probably already been attempted.
I think he has the sub already, and wants to make something work out of the stuff he already has.
Old Mar 19, 2007 | 03:14 AM
Robs07Tc's Avatar
ok thanks Yanki01!!! one more question well two accually. its easy to install i can do it 30min tops since i know what im doing now. 1.
How do you take the wire out of that so you can wire them up to a new amp. (Amp i was thinking of getting: http://www.bestbuy.com/site/olspage....=1134701342982 )
And where can i get sub wiring? i need it to connect to the amp i want and the sub im getting which is: http://www.bestbuy.com/site/olspage....=1134702499211
Please help.
Old Mar 19, 2007 | 03:52 AM
Yanki01's Avatar
ehhh, never liked sony or pioneer. i would go with elemental designs! A nine2 and the 11Kv.2 will be sweet!
Not too sure on the install nor the wires?
Old Mar 19, 2007 | 04:00 AM
Robs07Tc's Avatar
i like what i picked for now but can anyone answer my 2 ?'s
Old Mar 19, 2007 | 06:03 AM
Robs07Tc's Avatar
Please if anyone knows answer the two questions.
Old Mar 19, 2007 | 06:35 AM
exige's Avatar
ill answer a different non-posed question. will your sub and amp choice sound good?
NO.
dude...take our advice. the stuff you're buying is JUNK. sony amps are JUNK. pioneer subs are JUNK.
here's my recommendation for you.
Elemental Designs 11Kv.2 Sub
powered by
Elemental Designs Nine.2 Amp
what a coincidence...same thing yanki suggested.
rob pm me i can help you with your stuff....but we're giving you good suggestions. take it kindly and listen to what we have to say. we've owned the products ourselves and we know what this stuff is like. if you buy the other stuff you're gonna regret it later on. that sony and pioneer stuff just sucks.
Old Mar 19, 2007 | 11:08 AM
Robs07Tc's Avatar
i guess so. only adds 200 to my spending list. If i have the money i guess I will. Ill pm you later on.
Old Mar 19, 2007 | 12:31 PM
Yanki01's Avatar
save up if you have to and do it right! You'll thank us later!
Old Mar 19, 2007 | 03:04 PM
Robs07Tc's Avatar
ill buy is onc ei get the money
Old Mar 19, 2007 | 03:34 PM
exige's Avatar
pm'ed you back
Old Mar 19, 2007 | 04:31 PM
Robs07Tc's Avatar
thanks but i really just want to know how to replace the stock amp with a new amp and use that box ect. saves time and money.
