2007 HVAC Lighting Issue Fix
Old Mar 10, 2009 | 12:06 AM
engifineer's Avatar
Default 2007 HVAC Lighting Issue Fix
Background of Issue
Many of the early 2007 tC's have had issues with the HVAC lighting working intermittently or stopping all together. If your HVAC lighting only works sometimes, goes out when the headlights are turned on, etc, this is probably your issue. If the car is under warranty and the dealer is going to fix it, they simply replaced the HVAC unit. However, those that are out of warranty or have done an LED swap probably arent always so lucky. The remaining alternatives have been either buying a new HVAC (around $500) or purchasing a salvaged one ($50 - $100).
The Fix
I was finally able to get one of these sent to me that I could plug into a test harness and test. I spent some time mapping out more of the lighting control circuit (I had mapped a good amount of it previously during design of the LED mod for the HVAC, but not the input and dimmer control portion) and found the issue. I have since had one other person try this fix on theirs successfully as well, so while this may not be the only possible cause, chances are this is the one causing the common issue. The issue is a couple of cold solder joints on the legs of one device. The fix is detailed below.
1) Remove the HVAC. There are plenty of threads and DIY writeups on the forums detailing this part, so I wont add all of that here.
2) Remove the HVAC from the housing so you have the bare board.
3) Locate T302 on the front of the board right under the hazard button. This is a 3 legged device (a transistor) that controls part of the lighting function.
4) With a low power soldering iron with the tip tinned just a tad, reheat the solder joints on each of the three legs so the solder reflows.
5) While you are at it, go ahead and check T303 right next to it.
6) Plug it in and test. The lighting should now act as normal!
A pic is provided below for reference. If you have any questions on this or have the issue and this fix does not work for it, feel free to contact me on the forums regarding it. Going forward, I will check every 07 HVAC that I perform led mods on for this and resolder the device for good measure to prevent the issue from popping up.
Old Mar 10, 2009 | 12:12 AM
ack154's Avatar
Added this to this:
https://www.scionlife.com/forums/viewtopic.php?t=89149
Old Mar 10, 2009 | 12:18 AM
SILVERredLIPtC's Avatar
Thank you. I'm going to try this tomorrow morning and see what happens. I hate turning on my map lights to adjust my a/c.
Old Mar 10, 2009 | 12:24 AM
O5_TRD_tC's Avatar
sweeet
Old Mar 10, 2009 | 08:07 PM
raa-raa's Avatar
Hey Dave, is that my HVAC? :D
Old Mar 10, 2009 | 08:18 PM
engifineer's Avatar
No, that is actually just a random pic of an 07 board I had Yours actually did not have the issue, but I did check for it and made sure those solder connections were good before I put yours back together
Old Mar 11, 2009 | 02:55 AM
raa-raa's Avatar
^I just thought I would ask, haha. I am glad I have an expert working on my stuff :D
Old Mar 11, 2009 | 07:44 PM
superwhite08's Avatar
wow i wish i would have seen this when i had my tc - this really should be a recall
Old Mar 14, 2009 | 10:59 PM
MrScion07's Avatar
YEEEEEESSSSSS im selling my car and wanted to fix this. Mine used to come on if i did the old Fonzi slam on the side. Finaly it just stoped all together so im gunna try this and see how it comes out.
Old Mar 20, 2009 | 03:08 AM
ScichoBiatch's Avatar
Thanks. This fixed it.
Old Mar 20, 2009 | 03:21 AM
engifineer's Avatar
Cool! Glad it helped!
Old Mar 20, 2009 | 04:59 AM
joeya28's Avatar
so excited to try this
Old Mar 20, 2009 | 08:27 PM
bsptcftw's Avatar
Hey Dave, check your PMs
Old Mar 21, 2009 | 09:38 PM
NateV's Avatar
Fix worked just did it 20 min ago, lets see how it holds up. Good find man, thanks!
Old Mar 22, 2009 | 12:42 AM
engifineer's Avatar
Will be catching up on PMs and emails soon everyone. I had to work all day today and have had a 102 temp all day as well. Caught a nasty flu from someone apparently.
Glad the fix worked again. Looks like this is the one for sure.
Old Mar 25, 2009 | 01:20 AM
Garage1217's Avatar
Total sweetness Dave. Great work. Just got in an 07that I swapped about 2 years ago that came up with this issue. Sure enough, picked at T302 and it simply poped off without any effort. Soldered her back in place and BAM! LIGHT! Again countless thanks for this stellar find!
Old Mar 25, 2009 | 01:53 AM
DivisionbyZero's Avatar
Looking at T302 it looks like it was manually soldered on, like the factory pulled and originally installed the wrong component. The solder job was poor at best.
Old Mar 25, 2009 | 01:56 AM
Need4Bass05's Avatar
Nice! I thought this was just a singular problem, didnt know it was happening to others too.
Old May 21, 2009 | 08:05 PM
jazar07tc's Avatar
about 6 months ago mine stopped working and I was convinced it was the PIAA head lights that I installed. I never realized it was such a widespread issue among the 07. The dealer ordered me a new HVAC unit, which was $800 and change that the warrenty covered....but I have to pay (according to my extended warrenty) a $50 deductible which is BS and I'm gonna try to get out of.
Old May 21, 2009 | 10:34 PM
I tried to get mine changed out, but my dealership couldnt find anything about a recall, so they wouldnt do anything about it.
