alarm question: put a ground trigger on the door handle?
i have an alarm pro ca-330 factory add on alarm. it works essentially the same as the alarm you would purchase from the dealer, it also uses the stock key for arm/disarm
what i would like to do is figure out a way that i can have a ground trigger when someone lifts the door handle. my friends 95 grand am used to turn on the door light when you lifted the door handle (even when it was locked) and that worked really well for his alarm
i'm not sure how i would go about doing this though, i think i would have to fab up some sort of switch and bracket on the inside of the door. i'll take off the door later on today and check it out
ideas?
ideas?
i took off the door today, it doesn't look like it would be anything easy
i might be able to fab something up that would hold this switch:
it might turn out to be too much work though
boxzila
34
Jan 12, 2004 03:27 AM
