Amp and AVIC D1 constantly on even when car is off???
Old Jun 8, 2008 | 04:18 AM
808tC's Avatar
Default Amp and AVIC D1 constantly on even when car is off???
so today I go to my car and start it doesnt start. i open my trunk and see that my amp has been on the whole time while my car is off.
this isnt the first time its happened as my avic d1 would stay on when my car is off, but I disconnected the harness till i could fine out whats happening.
I have no idea how to address this solution.
heres some info. that might be useful:
-I have an HID kit (w/relay) and the ground to the kit is on the battery negative terminal
-the power wire from my HID kit and my amp are both connected (next to each other) on the batery positive terminal
-and of course my remote wire is connected from the deck to the amp.
-the ground wire to my amp is on a bolt somewhere in the back.
Please HELP!!!
Old Jun 8, 2008 | 04:32 PM
STNC's Avatar
So the amp is always on then?
Old Jun 8, 2008 | 04:52 PM
combatsteve's Avatar
well if the D1 is staying on then it will always keep the amp on so the problem is with the D1. Check your wiring behind the radio and make sure that the constant(yellow) and the acc(red) wires do not have any exposed wire and are touching. That would be my best guess without looking at it.
Old Jun 8, 2008 | 07:48 PM
808tC's Avatar
the amp was always on, yes. I kinda was thinking of this because the negative wire from the HID kit would complete the circuit for the amp or something...but i dont know
Old Jun 8, 2008 | 07:49 PM
808tC's Avatar
but the avic d1 harness was already disconnected, so I could look at it during the weekend. meaning, I disconnected the harness so the amp wouldnt turn on at all even when the car is on.
Old Jun 8, 2008 | 07:52 PM
07specTC's Avatar
I second this.
Old Jun 8, 2008 | 07:55 PM
07specTC's Avatar
He means to check your wiring connections from the D! harness to the factory harness.
Something is loose and touching or wires where hooked up wrong.
Old Jun 8, 2008 | 08:13 PM
datdude1119's Avatar
yeah it has to be the harness for the d1, it sends the signal to the amp through the remote wire to tell the amp to turn on or turn off
Old Jun 8, 2008 | 11:51 PM
808tC's Avatar
thanks...ill look it up and tell you guys the results
Old Jun 13, 2008 | 05:06 AM
any news?
Old Jun 13, 2008 | 01:45 PM
808tC's Avatar
i havent done it yet (i still got final exams)...after my final im going to look at the harness....as for now everything (amp and deck) is disconnected so nothing is draining power from the battery.....
thanks for the follow up!
Old Jun 15, 2008 | 12:09 PM
808tC's Avatar
alright so I looked in the back and sure enough, there were some exposed wires that may have been touching each other. I sealed them off with electric tape and the d1 stays off....for now. thanks for the help!
Old Jun 16, 2008 | 02:34 AM
cool glad you got that worked out
prescottn
Feb 24, 2016 11:57 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
O5_TRD_tC
Feb 18, 2015 09:01 PM
Irutt
Aug 4, 2004 11:58 AM
