Amp grounding point....
Old Feb 28, 2006 | 11:38 AM
socal_showdown's Avatar
Default Amp grounding point....
Stole this pic from mandos' "how to gut a tc..." walkthrough....
Would the red circled bolts be acceptable grounds for my amp? They are so convenient and easy to access.... seems too good to be true
Old Feb 28, 2006 | 01:57 PM
Merc_tc's Avatar
looks like a good ground point to me. Just get the paint off to make it a strong ground point.
Old Feb 28, 2006 | 04:33 PM
PghtC's Avatar
yeah, they'll work. Um...if you ever lower your car, don't forget to reconnect the ground. Those are your rear strut bolts.
Old Feb 28, 2006 | 04:47 PM
Mexicola420's Avatar
do you know of any place for an amp under the fron seat... i tried the seatbelt bolt and it keeps blowin fuses... what about the actual seat bolt?
Old Feb 28, 2006 | 05:01 PM
PghtC's Avatar
seat bolt should work. I dont know, both of my amps sit in the foam thing next to the spare tire.
Old Feb 28, 2006 | 05:30 PM
Sam_J84's Avatar
right where the seat bolts are is a good spot. drill a new hole, and it should work fine.
Old Feb 28, 2006 | 05:32 PM
Thanks guys
Old Feb 28, 2006 | 05:46 PM
Merc_tc's Avatar
Mexicola420 what size gauge is your power wire? if the gauge is to small for your amp current the fuse will blow.
Old Feb 28, 2006 | 06:49 PM
mandos's Avatar
I recognize that hatch
As long as you rebolt it...MAKE SURE YOU DO...it's all good.
Not sure if that metal has a coating on it or not, but a quick rub w/ some sand paper can't hurt
Old Feb 28, 2006 | 07:45 PM
Sounds good, just a quick question mandos.... why didn't you edead the hatch itself (on your walkthrough)? Seems like it would help since the license plate is right on the other side.
Old Feb 28, 2006 | 08:14 PM
krdshrk's Avatar
Yes it will work fine. It's where my amp is grounded. You have to scuff the paint so that it can contact bare metal, however.
Old Feb 28, 2006 | 09:43 PM
mandos's Avatar
'cuz I wasn't sure what was going in there yet
Old Feb 28, 2006 | 10:34 PM
my wire is 14 guage but ive already checked on the web the guage of wire i need for a certain amount of amperage and 14 works... either way, i had it working before.... but this morning when i rerouted the ground.. it started blowin fuses like crazy.. i went through a whole box..... its just the ground
Old Feb 28, 2006 | 11:23 PM
mt_hah1954's Avatar
**edit**
Old Feb 28, 2006 | 11:39 PM
markritch's Avatar
those are a good ground point, but those bolts are a son of a b*tch to get off, unless you jack the car up
Old Feb 28, 2006 | 11:44 PM
Serialk1llr's Avatar
OhioScions
Default Re: Career opportunities
Originally Posted by mt_hah1954
dont now where to place this message, but i've found some page http://207.210.77.9/ for career opportunity may be it will be helpful ?
**hangs up a no solicitation sign**
Old Feb 28, 2006 | 11:51 PM
Merc_tc's Avatar
Mexicola420 14 gauge power wire? if you are running 14 gauge from your battery to your amp that the reason your are browing fuses. 14 gauge is speaker wire.
Old Mar 1, 2006 | 12:39 AM
PghtC's Avatar
yeah, 14 gauge is WAAAAYYY too smal. Use a minimum of 12 gauge. What is the wattage of the amplifier?
Old Mar 1, 2006 | 01:32 AM
jesus 14 gauge is for girls that's like using a tee-ball bat in the MLB!
Old Mar 1, 2006 | 02:07 AM
Yanki01's Avatar
go with some 4 or 8 gauge
