Any DIY's or pics?
Old Oct 29, 2007 | 06:26 PM
tc1stgen's Avatar
Default Any DIY's or pics?
Does anyone have anything on hooking up an LOC and a remote wire? I have tried to research but I am not finding anything. Pics or a DIY would be really helpful!
Old Oct 30, 2007 | 12:31 AM
Whispaz's Avatar
LOC:
wrap all the black wire together and all the reds together on the LOC. connect those to a power source such as the wires to back speakers. T-tap or whatever the red (LOC) onto red (speaker) and black onto black (pretty simple) then when its hooked up, plug in the RCA cables
Remote Wire:
not sure which wire it is on the tC but if its the same as an xB (which it probably is) tap into the gray wire on the wiring harness that connects to your radio
Old Oct 30, 2007 | 02:53 PM
tc1stgen's Avatar
Ok on my LOC the only colors that I have are 2 gray, 2 brown, and 2 white. I know that with each color there is a possitive and a negative. On my harnesses I don't have a black wire at all.
Old Oct 30, 2007 | 03:56 PM
blackbelt38's Avatar
whats LOC?
Old Oct 30, 2007 | 04:10 PM
rvpps2rocks's Avatar
yea i was wondering the same thign
Old Oct 30, 2007 | 04:17 PM
why did you double post theres no need for it
Old Oct 30, 2007 | 04:37 PM
tc1stgen's Avatar
LOC is a line out converter
Old Oct 30, 2007 | 06:38 PM
Whispaz's Avatar
tie all the Neg. together and the same with the positives.
you dont need to connect the LOC to the wiring harness on the radio, just a power source. since the subs will be in the trunk, tap into the Pos. and Neg. of the speaker. makes it much easier by eliminating having to run the wires to the front
Old Oct 30, 2007 | 06:51 PM
tc1stgen's Avatar
Ok I have everything connected but the amp does turn on. I connected the remote to the gray wire in the harness. The power cable is connected to the battery and the fuse is not blown. Everything is connected to the amp and the fuse on the amp is not blown. I made sure that all of my connections were good and tight, but I have no idea what else could be preventing power to the amp. No I will say tha amp is used so could the amp be blown and would that cause no power to the amp? Outside of that I am stumped!!!
Old Oct 30, 2007 | 07:04 PM
Whispaz's Avatar
best thing to do is use a line tester to see if your getting power from the battery and the remote wire. you can reverse it to see if you have a good ground too.
you can find some real cheap for $1-2
Old Oct 30, 2007 | 07:07 PM
line out converts imo are retarded but they do work so w/e
Old Oct 30, 2007 | 07:08 PM
Whispaz's Avatar
i've never actually used one or even seen one. but i know how to hook it up.
buying a new HU is much easier IMO
Old Oct 30, 2007 | 08:15 PM
not just easier but better sound also. its just a lil box shaped thing that you splice into the stock harness and you get RCA in return . so imagine a box with 4 wires on one side and 2 rcas on the other..ive done one for a friend. it works if your on a tight budget
Old Oct 30, 2007 | 09:18 PM
ADRdesignCo's Avatar
on the LOC there should be about 5 wires... on the wire harness out of the stereo tap the RL+ (brown) to the L+, RL- (yellow) to the L-, RR+ (red) to the R+, RR- (white) to the R-. then for your remote you can use the grey wire which i believe is the ignition 12V+.
Old Oct 31, 2007 | 12:16 AM
4, 5...close enough hehe :D
Old Feb 10, 2008 | 10:18 PM
csorrows's Avatar
And you felt you had to double post just to point this out?? WTF??!!
EDIT: Use this next time!
EDIT v2: Sorry for bringing this from the dead. I did not check the last post date!
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Spitfire23
Scion tC 1G ICE & Interior
Sep 8, 2015 03:31 AM
StxArOne
Aug 29, 2015 03:29 PM
umnitza
Jul 25, 2015 07:54 PM
ilikepinktacos
Jul 11, 2015 10:20 PM
