Auto Shift Boot
Anyone has a shift boot on an Automatic? I want to put a leather shift boot. But I don't know if I can remove the plastic piece that acts as the rails for the auto's rails. And if I remove it will it still move like I still have that plastic rail there?
Lots of people done this already. But I don't know whether the plastic peice stays or not? I really want a leather shift boot but that means the plastic rail peice must go since it's really thick.
wouldn't that mean I need to convert my car to a manual which is $$$$ I still dont understand will my auto shifting still be the same (meaning shifting non linearly) if I remove the plastic piece?
No. You can remove the center cosole portion that has the shift plate and cig lighter and replace it with the same part from a manual. It will make the car look like a manual, but will still function just like your auto always did. You just wont be able to see what gear youre in.
Sorry guys I'm still a bit confused... I mean I want to remove the atual shift plate (i'm guessing that's what it's called). Will it still shift the same non linear way the auto is? I might do this soon and post pictures when I have the time.
There is a good chance you can fit a shift boot from a 5-speed over the "plate" that has the path for shifter to move through. The thin silver trim around this plate is exactly the same as in 5-speed, and the boot is not even glued to this silver trim, so if you have a buddy with a 5-speed tC you can try it before buying the boot.
the plastic rail will still be there. from what i know, ppl jus take the outer rim of the plastic rectangle off and place a boot over the shifter and jus put the outer rim back on to hold down the boot. thats how the ones i've seen were done
