big 3 bolt locations?
Old May 12, 2007 | 06:08 AM
Luc1f3r's Avatar
Default big 3 bolt locations?
im wanting to get this done on sunday but i want to make sure i know where all my spots are first...
1) Battery negative to chassis
batt is obvious, and i see where it bolts to the chassis
2) Alternator to battery positive
again, batt is obvious, and the alt point is on top of the alt, under the gray plastic cover, correct?
3) Chassis to engine
could not find this one/dont really know what to look for, where would i find these 2 bolts, have a pic or diagram?
im using a optima red top d34/75 with knu 1/0 wire
Old May 12, 2007 | 06:12 AM
Neothin's Avatar
Old May 12, 2007 | 06:29 AM
Luc1f3r's Avatar
thank you. but im sorry, im still not seeing where the chassie to engine is... is it on the back side of the engine, to where? and the extra pos wire is for your stereo, correct?
Old May 12, 2007 | 06:38 AM
Neothin's Avatar
engine to chassis... follow the 1/0 wire (silver) from the front left on the valve cover back along the intake manifold to the bolt underneith the intake. from there it connects with another wire that connects chassis-> battery neg.
and yeah the extra wire is for the stereo
Old May 12, 2007 | 11:14 AM
illiniguy's Avatar
Wow looks like you need to upgrade your terminals
Old May 12, 2007 | 01:31 PM
Luc1f3r's Avatar
ok, so really, just anywhere on the top of the engine to a grounding spot? im gona do it from the drivers side of the engine down to the same grounding spot as the battery, any reason not to do it like that?
Old May 12, 2007 | 04:58 PM
Neothin's Avatar
yea, i've got a yellowtop now with the sideposts... so it looks alot better.
just make sure that you sand off all the stuff on the points you use and get to bare shiny metal.
Fisqual
Sep 22, 2015 05:51 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
KILLER
Mar 29, 2015 05:32 PM
TCnewguy
Feb 16, 2015 03:50 AM
scioninla
14
Oct 18, 2003 03:46 AM
