Chrome Spray Paint Problems
Has anybody tried using the Dupicolor Instant Chrome Spray?? However when i think i am done, i handle the painted pieces and an imprint of my fingerprint is created. Its as if the paint is still soft for some reason. Here are the steps i used to paint:
1) Sanded down piece
2) Lay down the primer
3) Spray chrome paint, 10 min between coats
4) Let dry anywhere between 2 hrs to 24 hrs
I've painted trimpieces before but never used the chrome paint till now. I didn't use clearcoat in the end with the chrome paint becuase the top clear coat will turn the chrome dull and gray. Could that be the problem or should i try waiting longer, like a week?
Any input? Thanks in advance.
btw: the chrome paint before i handle it looks amazing.
I've not used the duplicolor chrome, but other times it has taken around 5-7 days for the paint to fully cure. For most paints, you can do 2 light coats and 1 medium coat to get a nice wet coverage without running. You probably just have to wait longer, and maybe get the paint to a higher temperature/lower humidity. Paint will set VERY fast in 85 degree heat with 30% or lower humidity.
The environment that you actually apply the paint isn't vital as long as it's in the range the manufacturer recommends. But after you paint, let it sit in a warm, dry area after the final coat for 48 hours or more. You want the paint to be hard, so that a fingernail won't dent it, before you put it in the car.
killahXB2
Mar 29, 2016 04:22 AM
Squishface
Sep 15, 2015 06:51 AM
my06tc
Jun 25, 2015 12:18 AM
