Components acting funny?
I have a Scion tC, I wired everything up to the crossover and to the amplifier, now I do not have these connected to my headunit because I still haven't gotten that from Fedex, but this is my situation.
When powering on the amplifier that is connected to the PG RSD components, I can hear a "thump" sound from the driver side components and not the passanger side, this happens when I turn the ignition key to [ON] and the amps power on, now another thing, I'm not sure why this is happening, but my sub is connected to my stock HU, when playing music on the stock rears , the sub hits hard and I notice the driver side components making a "thumping" sound and it sort of happens when the sub is hitting harder.
I do not have these connected to the sub amp, which makes me go . Should I wait until I get my head unit in and connected with the speakers before I jump back inside the car and start tearing ____ apart ? It's only the driver side that does this, the passanger is fine. Help please.
Thanks
Thanks
Originally Posted by tCeeJay
recheck your wiring. seems like you're sending a low pass signal to your tweets. are your tweets connected to the crossover units?
sorry dude, can't really say much since I'm not there and can't visually see whats going on. All I can say is recheck where you wired everything and recheck the amplifier settings.
Yup, I did check out the vid. Thats why i said "seems like you're sending a low pass signal to your tweets." because the sound coming from the tweets was the same as the bass from the background.
I turned the car on, took the speaker baffle off, and the tweeter and the speaker didn't make that noise...
Now when the magnet of the speaker contacted the metal door, the tweeter started making that weird noise again. What does that mean?
my driver side speaker started make this sound from last week. It's not loud as urs but it's still noticeable. I still have oem speaker with aftermarket sub and amp. It never happened for 6months since i installed my system.
For anyone else having this problem, my solution was bad amp. One of the channels on my 2 channel amp was bad, which is why it only happened on the driver side and not the passanger, i switched the passenger to the driver and the driver side was fine and the passanger side started acting up. I switched amps and all is well, I wasn't expecting to switch amps, now instead of 100+rms per channel, it's going to be 180+rms per channel with the new amp .
Thanks!
Thanks!
Klashan
Sep 24, 2015 12:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
