Dome lights stay on when set to "door"
For some reason my dome lights have been staying on when they are set to "door" and i lock the car. I noticed this a couple days ago and don't know why it's happening. Anyone have this same problem?? Thanks in advance for your help!
Im not really sure how or why the lights get hot but if i leave it off for a day or so, then set them to "door" they work fine but for some reason after a while they get hot and stay on....
Well of course If they're constantly on the lights will get hot, if you read my post correctly i said that with the dome lights setting to door, meaning they should only come on when the door is ajar, they stay on constantly as if i set them to the on setting ... With the car locked and lights set to door they will still stay on as if a door or hatch wasnt closed right or if i set them to the on setting... I haven't had a chance to look into it but hopefully i can get some free time tomorrow to check it out
If you read my post correctly, I'm referring to the door ajar warning light in your cluster panel and not your dome light.
This comment below is what's misleading...it doesn't happen when the light gets hot, the lens gets hot because it happens.
I just checked... it doesn't... and below the sensor on the door u can tell someone maybe tried to fix it because the little plastic screw isn't there... I just bought the car a week ago so I'm getting familiar w it... http://m.imgur.com/fMK6Laz where can I get that sensor?
I just checked... it doesn't... and below the sensor on the door u can tell someone maybe tried to fix it because the little plastic screw isn't there... I just bought the car a week ago so I'm getting familiar w it... imgur: the simple image sharer where can I get that sensor?
XB06
May 30, 2015 02:42 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
