Door and Rear Panel Suede
I was wondering how do you remove the cloth from the door insert and the rear panel? I'm planning to redo them in Red Faux Suede. If u can give me a step by step that would help.
it is a panel that the fabric is on you take the door off! then you heat the black posts that are melted over the holes holding the panel on to the door you will see them they go around the whole panel ! use a mini torch and clip popper to pop the panel off post by post than to put back togther if you did it right you can pop the panel back on the door and re-melt the posts back over the panel or use screws and washers
i used a mini torch let it make a flame and blew it out and used my clip popper to pry up the panel while the plastic was still plyable repeating till all clips were popped off of the door !
it seems tricky but its real easy once you do it one timmaybe there is a write up floating around ill check!
the doors on the matrix also have the lil plastic things..
what i did was drilled a hole small enought so the lil post doesnt break and the top just pops off then when you reinstall it just use screws =)
hey vietspeed if you need help let me know i can help you out
the tc doors are pretty easy looking compared to the matrix
