dynamat
Old Jul 12, 2007 | 12:52 AM
e246's Avatar
Default dynamat
does it really make your system sound better and hit harder thanks
Old Jul 12, 2007 | 12:58 AM
Luc1f3r's Avatar
hit harder, prolly on a meter... sound better, YES! (thats not a dynamat result, its a deadening result.)
SquallLHeart's Avatar
dynamat is a sound deadener... it helps with sound as in keeping outside noise and other stuff away...
it doesn't make your system hit any harder... it's sound deadening..
Old Jul 12, 2007 | 01:21 AM
Spect2K3's Avatar
It also helps the car sound a bit less like a tin can!!! yay!
Old Jul 12, 2007 | 03:20 AM
rocketgyrl's Avatar
This is one thing you can never have enough of. My car has somewhere around 350lbs of it, and I couldn't be happier. Matt stalled it 3X the day we put the car back together, because he couldn't hear the muffler!
Here's a good site: http://sounddeadenershowdown.com/
Old Jul 14, 2007 | 03:35 AM
GammaTNT's Avatar
wow, 350LB!!!!
How many layer you put on??
i was hauling 320 LB of cement , and the tc felt sluggish.
I think I will use 100 LB if i ever sound deaden my tc.
Old Jul 14, 2007 | 03:45 AM
rocketgyrl's Avatar
We used 3 different types of materials. The floor has 2 layers of "normal" butyl damping, then a layer of 1/4" foam and 1/8" rubber. The vertical metal panels (doors, rear quarter panels) have 2 layers on the outside, one on the inside. The trunk has two layers everywhere. The interior panels have a thick layer of Owens Corning Acoustic Blanket (sound isolation used in movie theaters) between the metal and plastic panel.
These are the products we used:
http://scosche.com/accumat.aspx?Cate...&ItemID=AMT250
http://scosche.com/accumat.aspx?Cate...&ItemID=AMT045
Similar to this:
http://owenscorning.com/quietzone/products/
Old Jul 14, 2007 | 04:26 AM
Mightygnu's Avatar
wow. some nice material.
horsefeathers
Mar 4, 2015 12:54 AM
Spect2K3
Scion tC 1G ICE & Interior
16
Dec 7, 2006 12:26 AM
riccochetrabbit
19
Aug 30, 2005 07:03 AM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
Chimmy3
38
Apr 25, 2005 04:43 PM
