ed setup
well, when I connect the voltmeter to the power and ground terminals, I've got power... when I connect the remote and ground, I've got nothing... so that's my problem, right? The remote isn't hooked up correctly.
Originally Posted by memoire
Oh wow. Thanks Mandos. Sorry for being such a dick earlier, it was really nothing to mount it, as I thought.
I do have a question though (everyone)... as my amp isn't powering up. I'm fairly certain I've hooked everything up correctly... I checked after the fuse with the car and radio on and I show voltage on the power cable at the amp, but no voltage when I check the remote wire -- I'm assuming this is the problem. What kind of voltage should I be seeing on the remote terminal at the amp? I connected it to the blue power antannae (blue with a non factory wiring harness) wire at the head unit... I imaging that should work... but the amp's not turning on at all.
If it's not the remote, could it be the ground also? I found a bold that I figured would ground it out, but I could be wrong. I hooked everything up afterwork... so, mostly by flashlight.
As for connection on the back of your HU, it should be connected to remote or ACC+. If you have it on the power antenna, it will only come on with the radio, not CD's or anything else.
You should see ~12V on the remote wire when testing across that and your ground.
Give me a call if you need any other help
I popped the head unit out today and was like 'duh'. I blame it on the fact that I was working by flash light last night.
I plugged the remote into the remote wire coming from the car, not the head unit. A quick switcheroo and everything's dandy. Thanks for the help.
vi3tb0i09
Sep 23, 2015 08:32 PM
dbg326
Aug 28, 2015 05:18 PM
Subaru86
Jul 31, 2015 04:33 AM
