engine noise can be heard through the radio
Old Mar 12, 2007 | 01:07 AM
Choose_Another's Avatar
Default engine noise can be heard through the radio
During idle and acceleration I can hear a high pitched engine noise
from the speakers. Actually it seems to be only coming from the rear
speakers in my car but not the sub. As I accelerate the noise gets
louder and higher pitched.
When I turn the radio off or put the volume down to zero it goes away
completely. Also it happened suddenly while driving down the road.
Once second fine, next WHINEEEEE
I have a Pioneer DEH-P4700MP installed in my Scion tC. I also have a
sub installed in the trunk.
Has anyone ever heard of something like this before?
Old Mar 12, 2007 | 01:11 AM
Yanki01's Avatar
i used to have it, untill i read this.....
https://www.scionlife.com/forums/vie...ight=ten+audio
Old Mar 12, 2007 | 01:13 AM
Yanki01's Avatar
its called the alternator whine, more than likley you have a bad ground. Make sure you sand down the ground good with no paint left, I re-did my grounds and it worked!
Old Mar 12, 2007 | 01:17 AM
Spect2K3's Avatar
If that doesn't work or you don't feel like dealing with all of that, get a ground loop isolator or two. If you are using a 4-channel amp, then you will need 2 ground loop isolators. Throw em on between the amp and the receiver and it should solve the problem. But if you would prefer to attack it from the source rather than adding a piece to eliminate it, then redo your grounds and make sure you have nothing interfering with something else. I used ground loop isolators for a while until I found out that it was the satellite radio. There is no way to ground that, so I threw a ground loop isolator on that one piece rather than on the whole system and it took care of it.
If the ground loop isolators between the amp and the head unit didn't work, then the problem is elsewhere. You can get em at www.crutchfield.com
Old Mar 12, 2007 | 01:21 AM
BrownDogg's Avatar
I actually just re-did all the wiring on my sound system. I had a custom system and sold it and put in a 2 channel amp for the speakers. I only have 2 speakers working! lol
But I had the same problem, that "whining" noise. I had a bad ground it fixed it. Try to make your ground as short as possible.
Old Mar 12, 2007 | 01:58 AM
Thanks guys, I bet it has to be a ground.
Makes sense too since it happened so suddenly.
Old Mar 12, 2007 | 07:15 AM
MPanova's Avatar
also make sure your signal wires and power wires are not ran together down the car, if they are run down seporate sides but some are lose back by the amp make sure they did not get moved around during driving and are now laying back there running parallel sp?
meowtc
Mar 5, 2015 02:28 AM
evolving_machine
Feb 27, 2015 09:53 PM
EvalEvan66
Jan 27, 2015 02:26 AM
evolving_machine
Jan 13, 2015 08:04 PM
swrdply400mrelay
Jan 9, 2015 01:10 AM
