Factory aux/iPod port
Old Feb 11, 2010 | 08:30 PM
terminal's Avatar
Has anyone triedto install a factory aux/ipod in the center console? I picked one up on eBay really cheap, so if anyone advice let me know...
The one that is attached to the 12v power outlet. Sorry...
Old Feb 11, 2010 | 08:36 PM
ack154's Avatar
Tried to install a what?
Old Feb 11, 2010 | 08:59 PM
terminal's Avatar
Default Re: Factory aux/iPod port
Edited for stupidty...
Old Feb 12, 2010 | 02:03 PM
terminal's Avatar
No one?
Old Feb 12, 2010 | 02:25 PM
asianorange's Avatar
Here you go.
http://www.club-tc.com/forums/audio-...-headunit.html
My advice:
1. Check your headunit to make sure it supports the iPod. Unless you are 110% sure it has the iPod connector in the back you need to physically inspect the back of the headunit to be sure. The plug you're looking for is located at the bottom left corner in the picture below.
2. Make sure the prewiring exists. I think only starting with '06 or '07 did the standard harness include the cable section that ran from the handbrake to the headunit. In the empty space behind your headunit you should find a spare connector as illustrated in the link.
Old Feb 12, 2010 | 04:10 PM
terminal's Avatar
So if I have an 05 will the aux port harness be there or will I need wiring?
Old Feb 12, 2010 | 04:46 PM
Did you read the link? This is what I get for answering things that could be found on searches.
1. I only know about being able to do this '06 and up.
2. you'll have to pull the dash to check for the following:
a. A 4th extra unused plug behind the radio that fits the headunit or similar I posted earlier. This is the iPod cable that comes prewired starting '06 to the best of my knowledge
b. the other end of the ipod cable right by the shifter cage
FWIW there's three segments to the cable.
1. the one listed above. that runs from the shifter to the back of the headunit
2. one that goes from the connector by the shifter to the knockout in the armrest compartment PT546-210621
3. the final segment from the compartment to your ipod. PT546-21062
You need to check under the console to see if you have the first segment. Otherwise off to the parts yard you go
Old Feb 12, 2010 | 06:12 PM
terminal's Avatar
I actually read the link after I replyed... Thank you sir!
Old Feb 12, 2010 | 11:08 PM
Hope this works out for you. If the cable is actually there that would be good to know.
steeze69
May 24, 2021 02:57 AM
Klunkerbill
Nov 9, 2015 11:39 PM
Renuco612
Sep 16, 2015 09:01 AM
dyenfd
Sep 13, 2015 10:00 PM
