Firewall Location????
In the TC, on the drivers side there is a boot assembly already in place. In the engine bay, look at the firewall on the drivers side follow the wires and you will see it. It's kinda low, so look down half way. You will also see a few plug nipples sticking out, cut one off and there is your opening. It is much easier to feed from the inside of the car out. Use a little wd40 on the wire and it will slide right thru.
You can also see it from the inside, to the right of the steering wheel, under dash area.
Darrenohooligan
Sep 26, 2015 07:21 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
