Front component speaker wiring question
Old Feb 11, 2007 | 01:56 AM
jwaggz82's Avatar
Default Front component speaker wiring question
I have Infinity Components for the front. My component xover box has the following wire layout:
_______________________________________
| -IN+ | | -WF+ | | -TW+ | | -3dB. |
Which wires go to what? You have your pos. and neg. wires that go to the amp. Then the WF would be woofer? and TW tweeter? ..im guessing?
What exactly is the last one on the right .. -3dB ??
Thanks guys for the help.
Old Feb 11, 2007 | 11:41 AM
fujitech43's Avatar
I think its for the tweeter, my component set has a switch on them labeled +3dB. the manual says "We have added a switch inside the crossover to allow either flat, musical response or +3dB from tweeter if desired." I bet yours just has a different terminal instide of a switch. Just try it out and see which one you like better
Old Feb 11, 2007 | 08:20 PM
tweetertc's Avatar
well... as follows
amp in, woofer out, tweeter out, tweeter out... the negative 3 db is for personal preference in sound output... what it does is makes the highs less intense.... so that way your not choking on highs... usually i set mine on the lower setting cause you can always increase your treble on your radio if you want it a little brighter...
Old Feb 15, 2007 | 04:07 AM
jwaggz82's Avatar
How is everybody running the speaker wires for their front tc speakers? I took the door panel off .....saw what little i was working with ...and put it right back on.
Old Feb 15, 2007 | 04:11 AM
L4rry_B1rd's Avatar
i ran them thru the door grommet. used a long zip tie, lubed it up a bit, taped an end of the speaker wire to it, and began to snake it thru.
Old Feb 15, 2007 | 04:25 AM
SLOtC's Avatar
if you want you could use the factory wiring... very clean look no wires to push threw the door
Old Feb 15, 2007 | 04:28 AM
jwaggz82's Avatar
Ah - yea - but i dunno. The factory wire crackles when you turn it up. Thats a main reason why I wanted to switch.
Old Feb 15, 2007 | 04:32 AM
jwaggz82's Avatar
Ya - thats what I was thinking but when I looked into the car it looked asif there was no room at all for anything.
Old Feb 15, 2007 | 04:35 AM
SLOtC's Avatar
my speakers are amplified and its clear, no crackles... but if you want to go threw the door you could use a wire hanger if you needed somthing stiffer then the ziptie
Old Feb 15, 2007 | 04:36 AM
L4rry_B1rd's Avatar
just snip a bit of the tape away from the wires and there should be plenty of room to work with. i didnt mount my x-over inside the door so I actually ran two sets of speaker wires and they fit fine. if you mount the x-over in the door, you only need to run one set which makes things easier...
Old Feb 15, 2007 | 04:43 AM
jwaggz82's Avatar
^ Ill need to run 2 sets myself. Theres no way im putting the xover in the door.
Old Feb 15, 2007 | 04:45 AM
L4rry_B1rd's Avatar
my sentiments exactly. good luck.
oh, and the zip ties I used were the thick, heavy duty ones from Home Depot. they are stiff enough to be able to work thru the grommet yet flexible enough to bend along the curve of the grommet.
Old Feb 15, 2007 | 06:25 AM
Neothin's Avatar
why wouldn't you moutn the crossover in teh door? yeah there's water... but i put the xover in a ziplock and taped the end. No water watersoever is going to get to it.
Old Feb 15, 2007 | 03:14 PM
jwaggz82's Avatar
sucks because I had this zip tie that was really big .....i never saw one so big ...ide bother the guy in the cube next to me at my last job.... i had no clue I should have taken "the big zip tie" when i left - ha.
DaBlackBox
134
Apr 10, 2022 02:04 PM
Erickdimas7
Scion tC 2G ICE & Interior
Jan 16, 2015 03:41 AM
cwong1001
Dec 3, 2014 03:30 AM
rolex87
Oct 17, 2005 01:00 PM
vpkb
12
Oct 8, 2003 04:17 AM
