fuse blown radio not working and gauges not lighting up?
Old Jan 26, 2010 | 06:57 AM
agencytc's Avatar
Default fuse blown radio not working and gauges not lighting up?
How do i know what fuses are blown the gauges wont light up and the radio wont power on?
Old Jan 26, 2010 | 07:13 AM
SquallLHeart's Avatar
reading towards the back of the owner's manual will point you to the correct fuse.
Old Jan 26, 2010 | 07:43 AM
agencytc's Avatar
thanks
Old Jan 27, 2010 | 06:21 PM
agencytc's Avatar
Default NO power to the radio :(
So i messed something up installing my fog lights i tried running the switch power wire for the fogs to the radios power cable worked for a bit but then the radio stopped working. The oem radio now and double din that i have are both not working because i am not getting any power to it. i checked all the fuses and the ones that were blown i swapped out and i am still not getting any power. Does anyone know what the problem could be?
thanks i appreciate it alot.
Old Jan 27, 2010 | 06:35 PM
O5_TRD_tC's Avatar
you checked both fuse boxes?
Old Jan 27, 2010 | 07:54 PM
scion_andrew's Avatar
fuses samething happened to me
Old Jan 27, 2010 | 07:59 PM
FlintMica2005's Avatar
radio is usually your ACC fuse under the steering wheel, I drove around for 6 months till someone on here told me that was the fuse
Old Jan 27, 2010 | 11:48 PM
your ACC fuse..
Old Jan 28, 2010 | 02:32 AM
mattieg's Avatar
Peek your head under the foot well on the driver side. Your radio fuse is also your cigarette fuse. The fuse should be a ten amp if I believe labeled CIG.
Old Jan 28, 2010 | 04:34 AM
agencytc's Avatar
yeah i checked both and the ones that were blown i changed out and still no power
Old Jan 28, 2010 | 05:02 AM
so there were blown fuses...
you check those fuses again? they probably blew again.
you didn't fix the problem by replacing the fuses... since you didn't fix the reason why they blew in the first place.
Old Jan 28, 2010 | 06:37 AM
agencytc's Avatar
yes there were and i replaced them. and i have checked them and they are fine but i am still not getting power. i fixed the reason that they blew so idk anymore
Old Jan 28, 2010 | 07:05 AM
you must have installed the fogs with the battery connected right?
I have no more solutions, I thought it would abeen the ACC. it could just be the radio itself that died out.
Old Jan 28, 2010 | 07:20 PM
agencytc's Avatar
the radio works i had a power source going to the radio power wire and it works but idk i guess dealership
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
mattjk
121
Dec 22, 2004 10:49 AM
MaxPower
Oct 22, 2003 09:22 PM
