Gauging interest in interior led lighting....
I have built some prototypes for led interior lighting. They are insane bright. Just 6 of the leds strung together makes a 12" cathode look boring and dim. Just 3 of them strung together equals the light output of a 12" cathode / is brighter than a 12" cold cathode. I use superflux leds in the design which are very high quality and have an amazing lifespan. I have 3 models I am testing on the bench and will continue to test for another week of solid use overdriven at 14.6V "scions run 13.8V running and 12V with ignition off" For testing I am overdriving the crud out of these babies to insure I have a reliable product. I have already tested on the bench over a week straight. If I am to build these, they will be rock solid and carry a 1 year no hassle exchange warranty if you have an issue "barring physical damage" as I have that much confidence in them. Let me know if you guys are interested....
Key points of why I am building my own light assemblies
- Superflux is equal in brightness to a w6led superbright led model used in most dome light conversions. "just using as a comparison as I do not have bulbs ready yet" Also are infinitely more reliable as I have found over a long span of time a fair failure rate in white w6led model led bulbs "reason I stopped carrying them"
- Cathodes never seem to match exactly in color when lengths are changed. This sucks when building a show car and everything has to be perfect. The led lights I am building are an exact color match in any length.
- I can power approximately 30+ superflux leds with the power drawn by just 1 cathode transformer. This means you can have your car on and glowing at shows for hours longer than cold cathode setups.
- No stupid bulky ac transformer to mount close to the cathode tubes.
- My design makes it possible to flex the string of leds to form around shapes or objects.
These are NOT for sale yet, I want to continue testing to insure a perfect product. Let me know what you guys think!
your price on the individual ones will have to come down a tad to compete-
http://www.oznium.com/prewired-superflux
Thanks for the info. They are selling theres for $3.69ea unless you buy 10 or more, then they are $3.29. I already beat them by 19 cents each on small orders and am happy to sell them for $3.00 each on qty's larger than 10. I think this is more than fair
Will do, so far so good. I have some really unique ideas to make install simple, fast, hidden and reliable. Going to work hard to develope these ideas and apply for some patents. I think the end result you guys will LOVE!
Originally Posted by Garage1217
I have allot on paper... And yes, a dome light set that is affordable / provides enough light to read without issues is in the works
Oh it is! Also update on testing! 11 days and counting of solid use. 0 issues except I had two 3mm cheapy leds that a customer sent in die within 12 hours of use each
But the good news, all the superflux are flawless! I have all colors on the board setup as single leds, and in series of 3. Next testing, they are going into the oven for a day or two being overdriven at 170F. If they can pass that test :as cars in arizona reach 160+F on the interior in direct sunlight" then I will start production. Just have to make sure I have a reliable product!
Yes it does turn out a magenta that way as they leds are rather focused light, that and even right next to eachother you would get blueish red hot spots.... You can however take a blue led and use a red filter and make a nice purple, but is not super bright.... You can also use a hyper white and then use purple translucent vinyl to make the color... But I have to work on those projects seperate as the basic colors are number 1 right now "red, white, blue and green"
