HELP!!
Ground for amp?????mine is under back seat
Remote for stock deck not sure.....
Power for amp comes from battery and be sure to use proper guage wire or it will blow fuses and possible theamp
Oh look under the dash at the steering column and you will see a rubber bootie with wires through it.......carefully cut the tape oround the bootie and pass your power wire through that.........there is also one behind the glove box with less wires......but the best straightest shot is by the column.
it will fit 0/1 wire but you need help to get it through as it is tight.
no problem.....just pull off the lower dash cover ,you will see hat i meen and you have full access to the area under the column.......
you got to have a helper to get anything larger than 4guage through the grommet though as my 0/1 was a nightmare to get through.I had hemostats pushed through and my wife stuck the wire in it and I pulled while she pushed.......took me 30 minutes to get it all through...lol
