Help with auxiliary cable. *Edit* Problem solved on 2nd pg
Hey guys, I have just recently purchased a Kensington Liquid Aux Deluxe for my Iphone3g. It hooks up to the power supply outlet in the center console, along with a plug that hooks into the auxiliary outlet. While driving I hear a spooling sound, like the one that comes from manual transmissions, but through my speakers. Whenever I drive faster, the sound gets faster and seems like it's matching my RPMs.
So I'm not really sure if I should bring this to the dealership or not. I am still under warranty, and I have used an auxiliary cable in the past for another ipod. But that auxiliary cable stopped responding. Any help would be nice, thanks!
*Edit* Could it be that since it's connected to my power supply as well, it may be draining my power causing the speakers to make that noise?
Originally Posted by jackotamo
Its a feature the stock radio has. The sound gets louder as you go faster. You can turn it off.
i think its a little more than that .
What happens when you disconnect the power supply?
It gets to the point where I have to disconnect the entire thing because the noise either gets annoying or too loud. Especially when I drive on the highway.
Solutions anyone??
Just run it without the power supply. I leave the auxiliary cable plugged in in my car even though I don't have an iPod (my friends bring theirs every now and then). I noticed if you leave the stereo on AUX mode and theres nothing connected to the end of the auxiliary cable, the stereo will put out a clicky noise that matches the engine RPM... As for why it does this? I DON'T KNOW! Might not even be related to your problem...
Unfortunate for me, there is no separate aux cable
. I would post a pic of it for you guys, but I'm late for work already. Thank you for your help, I think I'll just make a quick run to the dealer on monday or something. See if they would replace it for me.
It sounds to me like an electrical interference issue like we used to get on the older cars equipped with a distributor. The ignition (distributor and wires) leaks-off electromagnetic energy that manifests it'self as noise through your speakers. You can purchase a filter to reduce the problem.
i was just speaking to a co worker about this and he suggest using a "ferrite bead" and another personell suggested a "dehummer" .
the dehummer shound like BS as i cant find any info on it
you need a ground loop isolator
it has nothing to do with the ASL AT ALL and has more to do with the ground being poor in the aux port.
they fixed that in the '08+ by placing a ground for the aux (which they should have done so in the first place)
