Help with auxiliary cable. *Edit* Problem solved on 2nd pg
Old Aug 17, 2008 | 01:34 AM
Slikk's Avatar
Music City Scions
Originally Posted by SquallLHeart
you need a ground loop isolator
it has nothing to do with the ASL AT ALL and has more to do with the ground being poor in the aux port.
they fixed that in the '08+ by placing a ground for the aux (which they should have done so in the first place)
is there some kind of recall for that?
have you corrected this issue your self? where did you get your ground loop isolator.
Also the ferrite bead doesn't help
Old Aug 17, 2008 | 02:43 AM
Illusion's Avatar
Thank you all for your help! I'll post back once I get the ground loop isolator or ferrite bead so I can verify if it does actually solve the problem.
Old Aug 17, 2008 | 02:48 AM
paulky_2000's Avatar
An eBay search turned up 83 matches for "ground loop isolator"
Old Aug 17, 2008 | 02:52 AM
Slikk's Avatar
Music City Scions
ferrite bead doesn't work .. i just tried it
Old Aug 17, 2008 | 03:12 AM
Illusion's Avatar
Oh, I forgot to ask. If I do get the ground loop isolator, is it an easy install? Just plug and play, or do I have to remove the little center console area.
Old Aug 21, 2008 | 12:28 AM
Illusion's Avatar
Sorry for the late reply, but I have finally bought all the necessary things to tackle this problem. It wasn't cheap either.
#1. Kensington LiquidAux Deluxe package - ~$70
#2. Auxiliary cable -> Dual red+white wire -$7.69
#3. Ground loop isolator -$18.31 inc tax
#4. Red+white wire -> Auxiliary cable - $3.99
So in the end, I paid about 100 dollars for this setup, 30 dollars if you don't buy the kensington liquidaux deluxe like I did. I do like it, and it works like a charm, the only downside is that there is one wire leading from my waterfall to my center compartment box. I wonder if I can drill a few holes to hide it.
PS. Ground loop isolator = success, just try to find one that goes from auxiliary -> ground loop isolator -> auxiliary, that way you don't have to buy so many things like I did.
Old Aug 21, 2008 | 11:25 AM
Slikk's Avatar
Music City Scions
Nice fix. I saw this one on Ebay but it doesn't connect to the power supply do you think it will work ?
Old Aug 21, 2008 | 12:13 PM
Illusion's Avatar
You'll need another auxiliary cable that will connect to a media player/mp3 player for it to work. But yeah, it'll work Maybe I should have bought this one....
Old Aug 26, 2008 | 01:46 PM
fmtc's Avatar
don't buy anything! there is a TSB on this: S-AU005-07. Take it in and have the dealer fix it.
Old Aug 26, 2008 | 02:09 PM
equinox2355's Avatar
If you have access to that, is it 3yr/36,000? or is it higher?
Old Aug 26, 2008 | 08:04 PM
fmtc's Avatar
3yr/36,000 only sorry
Old Aug 30, 2008 | 08:52 PM
aen's Avatar
aen
you should have asked me steven, i had a isolator that came with my headphones...it's a single one.
i forgot about it till i read this thread and realized what it was haha
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
evolving_machine
Feb 27, 2015 09:53 PM
UltraCronic
Feb 11, 2015 06:55 PM
Inazuma
14
Apr 6, 2004 06:29 AM
