Help with finding 08 tC LEDs
Old Sep 28, 2007 | 02:25 AM
stc08's Avatar
Default Help with finding 08 tC LEDs
i want to put in blue LEDs in my maps, and rear dome lights in my 08 tC, i found a picture of another tC with the exact color i am wanting, but i am not sure where's a good place to get them or what type i will need, any help would be appreciated, well here's the pic:
Old Sep 28, 2007 | 03:30 AM
BZinn1's Avatar
Oznium has them......if I remember correctly.......I just moved so all my papers are MIA.......the 16 fits the back and the 25 fits the front.......both come withthe pieces to fit it into the socket.......reminds me I gotta order mine in orange .......
Old Sep 28, 2007 | 03:59 AM
TheQuietThings's Avatar
superbrightleds.com has them
awesome LEDs, and lifetime warranty.
About 4 bucks a pop for the front domes and about 3 for the rear.
Old Sep 28, 2007 | 07:53 PM
stc08's Avatar
i found out that my 08 tC will take (3) 9-LED's in my front map lights, but now for the rear dome light i was told that i could also use the same LED, but only would require (1)..these are awesome bright blue, just like in my picture, but whats got me confused is that another place told me that i would need (2) D31mm LEDs for the rear dome..i just want to know if in fact the 9-LED could be used in the rear, because if it does, i am definetely getting it..
Old Sep 29, 2007 | 11:02 PM
simon-says's Avatar
I have an 08 tC and just replaced my lights with LEDs from superbrightleds.com. I put the 3022-x9 in rear dome. It is a very tight fit, but it will work. I put the 921-x9 in the front map lights as well as front dome. They fit with not problems and are bright. I went with blue in the domes and white for the map lights. I might upgrade to 921-x12 in the future for the front. Put the WLED 5-LED Wide Angle LED in my license plate bulbs, they are pretty bright as well. Next I will upgrade the trunk cargo light. But this was a very nice upgrade for just a little over $20.
Old Sep 29, 2007 | 11:13 PM
stc08's Avatar
how many did you require for the front, and the rear, and do you have any pics
Old Sep 29, 2007 | 11:35 PM
simon-says's Avatar
Front:
Rear:
Kind of blurry. Just know the lights are much brighter than the camera picked up. In the front there is 3 bulbs (2 map lights, and 1 dome light). In the back there is just the one. In the pics I only have the front and rear dome on, map lights off. A little trick, on the front bulbs get a rubberband and wrap it around the lights to use as a grip. You won't twist them, just kind of wiggle and pull them down. Check out the thread in the link below. He used smaller bulbs than me, but the ones I got fit. I do not have pics of license plate bulbs yet, but trust me it looks real nice.
https://www.scionlife.com/forums/viewtopic.php?t=53930
Anyone else interested here is what I used.
Front (2 map lights + 1 dome light = 3): 921-x9 (though I bet the 921-x12 fits)
Rear (dome = 1): 3022-x9
License plate (2 for left and right): WLED 5-LED Wide Angle LED
Old Sep 30, 2007 | 12:30 AM
stc08's Avatar
why did you go with the 3022 -x9 when the 3022-4 LED Festoon bulb was recommended, did you find this one was better
Old Sep 30, 2007 | 01:08 AM
simon-says's Avatar
I saw somewhere in the thread someone went with the 3022-x9 and it fit so I gave it a shot. I did not try the 3022-4. My only basis for going with bigger bulbs than the first guy in that thread was I wanted it bright, these bulbs succeeded in that. When I place my order for my cargo light I will get the 921-x12 bulbs for the front.
Old Oct 1, 2007 | 02:42 AM
Oznium_com's Avatar
Skip superbrightleds, go straight for this dome light. I promise this is the brightest ever:
http://www.oznium.com/thin-led-domelight
Small fits in the front of the tC
Large fits in the back of the tC
Old Oct 1, 2007 | 02:52 AM
$30
Old Oct 1, 2007 | 03:38 AM
stc08's Avatar
$30
$60
Old Oct 1, 2007 | 04:06 AM
$30
$60
$25 for the small
$30 for the large
$55
Old Oct 1, 2007 | 04:20 AM
Oznium_com's Avatar
And you could also put a total of 3 up front, making it even more expensive! These are a very fair price for how bright they are.
Old Nov 20, 2007 | 01:02 PM
aznaflacattack's Avatar
what does the law say about the color of your License plate bulb?
Old Nov 20, 2007 | 09:48 PM
XIEmperorIX's Avatar
My assumption would be as long as it can be seen clearly? So I probably wouldn't change it to anything other than white.
Old Nov 21, 2007 | 05:05 PM
WAlterEgo's Avatar
typcially white.
horsefeathers
Sep 17, 2023 11:12 PM
airmankevin1
Feb 14, 2018 01:23 PM
XB06
May 30, 2015 02:42 AM
terrye
Feb 20, 2015 03:27 PM
scsteven
Jan 25, 2015 01:06 AM
