HELP with my subs
Old Jul 20, 2008 | 08:27 AM
delgado898's Avatar
Default HELP with my subs
Setup:
2 Kicker CVR DVC 10" Subs
Power Acoustik 2600W AMP
I have a sound on all the time the amp is on.
It sounds like if they are constantly thumping at a low level, Even when the HeadUnit is OFF.
What can i do to fix this?
thanks
Old Jul 20, 2008 | 09:54 AM
SquallLHeart's Avatar
put a switch in to turn off the amp.
Old Jul 20, 2008 | 10:01 AM
delgado898's Avatar
i think ima have to do that, but should i leave the stock sub connected?
Old Jul 20, 2008 | 03:43 PM
nebster's Avatar
what headunit do you have? because there is no reason the amps should be getting a signal if your headunit is off
Old Jul 20, 2008 | 03:59 PM
ZTC's Avatar
ZTC
no different size subs plying the same music will give off cancellation
just disconneenct the sub
Old Jul 20, 2008 | 04:54 PM
trialsindude's Avatar
Strictly Scionized
LOLOLOLOLOL
Old Jul 20, 2008 | 06:40 PM
wazzu_coug's Avatar
disconnect the stock sub. it sound like aweful anyways. your problem with the amp is that the remote wire is not connected correctly. It should be connected to the remote/amp wire on the back of the head unit. If it is staying on, you have it connected to a constant 12v source.
Old Jul 20, 2008 | 06:56 PM
delgado898's Avatar
I have the 2008 premium Head Unit, I have the remote cable connected to the cigarette lighter
Old Jul 20, 2008 | 07:05 PM
nebster's Avatar
you're loc is f'd
Old Jul 20, 2008 | 07:14 PM
delgado898's Avatar
^^^^what do u mean?
nebster's Avatar
don't you have a line out converter for the amp?
Old Jul 20, 2008 | 07:22 PM
delgado898's Avatar
I didn't use the line out converter since the HU has SUB outputs
Old Jul 20, 2008 | 07:30 PM
nebster's Avatar
oh yeah i forgot that thing has preouts now. hmmm sounds like an issue with the amp or headunit. my guess is the amp
Old Jul 20, 2008 | 08:09 PM
delgado898's Avatar
i think i have to tune it or something
ill be messing with that later
Old Jul 20, 2008 | 08:35 PM
wazzu_coug's Avatar
you just answered your own question. you have the remote cable connected to the cigarette lighter, meaning that the amp will be powered on any time power is supplied to the cigarette lighter (ACC power). This is incorrect. You need to have it connected to the remote wire on the back of the headunit; meaning that the amp will now only be powered on when the headunit is on.
Old Jul 20, 2008 | 08:52 PM
delgado898's Avatar
i think i did lol
thanks
BlingSlade
Oct 19, 2016 12:39 AM
crimson10tC
Sep 10, 2015 08:44 PM
umnitza
Sep 1, 2015 08:06 PM
javio24
Aug 23, 2015 01:07 AM
sethmskinner
Aug 4, 2015 02:38 AM
